Question about Nintendo DS Lite Console
Ds says it can not locate the game card, which is inserted. Have tried different games, have tried cleaning intake area. Have removed battery.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
The card slot is loose.
Posted on Jul 16, 2010
  • jleegrubb Sep 24, 2010
    Additional step but be careful! I found my kids were licking the game cartridges to get them to play in their two DS lites. Finally none would play. Cleaned the game cartridges with 80% alcohol dampened (not dripping) Q-Tips, gently wipe w/clean cloth, and allow to dry. Still none worked. Figured the game slot pin were coated in spit or oxidized. Took a cheap thin emery board for doing nails, used the fine side toward the pins and gently (going directly in and out so as not to bend the pins sideways) abraded the pins. Blow gently to remove any dust. Now both machines see all cards all the time.
I bought a brand new DS lite online, it functions perfectly when switched on, but when I insert a game card it immediately switches itself off. if I insert the game card before turning the DS on, then it...
I had just repaired two of these with the same problems, and ran into two different solutions! First solution is too check with a little flash light inside the game cartridge area where you insert the game for bent pins that may contact each other when the game is inserted, the solution is to take apart and repair the bent pins by straightening them out, or buy a new cartridge holder from ebay to solder on the board. This fixes no read and shut down of ds, and is a permanent fix, until someone jams a cartridge back in and bends the pins again.
The other fix, is to buy a new motherboard I found that one had a circuit malfunction which caused this issue.
Most likely and a lot of times it is in fact bent pins causing this because when inserting the game into the cartridge area over and over with force or putting it in backwards and forcing it by someone that doesn't know any better will create the problem and that leaves you two options I stated above: If you can fix the bent pins you might have success, if you can solder, you can replace the game cartridge on the motherboard, and or replace motherboard if that failed. If you don't do none of these you have the option to get it repaired, sell it back on eBay.
The pins are fragile and can be bent in ways not repairable in that case you would safe time and effort to buy a game cartridge on line, cheap few bucks, and solder it onto motherboard to fix your issue.
Just look for game cartridge slot reader for your type of ds on eBay! Good Luck!
Oct 24, 2013 | Nintendo DS Console
"there is no ds card inserted" error appears even
Check for broken or bent contact pins on the card slot. If all seems fine in there, try cleaning it up.
Jul 12, 2011 | Nintendo DS Lite
When games are inserted into console they will not play
If you are inserting a DS card, be sure there are no foreign articles inside the slot. Blow into the DS card slot to clear any debris. Also be sure you are inserting the card all the way in until it clicks. I've also found that if you're powering on a game, and you bump, grasp or touch the ds card as the DS is powering on, that can cause it to not read games.
Check the actual DS card itself and carefully look at the exposed contacts on the circuit board. Be sure none of them are scratched, damaged or otherwise. A scratch can damage a contact, thus preventing proper data read.
If anything was spilled onto the DS card, be sure it is thoroughly cleaned with a damp cloth (no cleeaning chemicals!) If you immerse the DS card, or pour liquids on it, that may damage it as well.
Same points hold true for inserting a Gameboy Advance game (if you have a DS or a DS Lite. The DSi and DSiXL do not have Gameboy Advance slots.
If you turn on the DS and nothing happens, try a different DS Card. If it only happens with that one particular game (or games) your DS cards are damaged or need cleaning. If all your games are not playing, there is a problem with your DS. Try your games in a friend's DS just to make sure. You'll probably have to send the unit to Nintendo for repair, or take it to an authorized repair center.
Dec 05, 2010 | Nintendo DS Console
Ds lite no game inserted
Look down in the cartrage area and see if one of the pins has become broken or bent. This is the most common problem for this symptom. If this is the case, then you will probably have to take it to your local game store for repair.
Dec 09, 2009 | Nintendo DS Console
Why does it say that there' no ds card inserted
It just could be that it needs to be cleaned.
Turn off the system.
Remove the card and blow into it. Allow the dust to be removed from it and push the card back in.
If it doesn't work try it while the ds is running.
Otherwise your card reader is damaged and needs to be fixed/replaced.
Nov 22, 2009 | Nintendo DS Lite Console
DS lite does not recognize inserted ds game card.
jvnabc try blowing into the ds and your game
Aug 02, 2009 | Nintendo DS Lite Console
Cant play games on nintendo ds lite
I can tell you.You might have to clean the back metal strips on your Ds game or game Pak.Also the game pak's internal battery has runned dry.Use a cutip to clean inside (works on Ds games)Turn on and off the Ds muiltiples off times and it should have work.I tried it and it worked.
Dec 27, 2008 | Nintendo DS Lite Console
Ds lite,
Hello, turn it off with and get out batteries and then restore them again, then clean pin of you game card and if you can the pins of you machine.
Sep 07, 2008 | Nintendo DS Lite Console
Action replay causes lock-ups/DS card problems
take the game out and blow in the DS card slot put the game back in and if that doesn't work take it to a game store ask them what you should try
Apr 03, 2008 | Nintendo DS Lite Console
Console does not recognize ds or advance games
you have to have the machine off anytime you insert or remove a card or cartrige thats not a glitch its to keep from shorting
Nov 02, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
175 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
