Question about Intuit QuickBooks Premier 2009 Full Version for PC
How to load data base into quickbooks pro so it is a click away
    Guru:
  • 195 Answers
From there, it's easy to invoice clients in a few clicks so you won't miss any ... Based on 2008 survey of QuickBooks Pro & Premier customers who expressed an opinion ... Easily transfer your existing data file into QuickBooks 2010. ... Quicken 98 through current version can be transferred to QuickBooks 2009. ...
quickbooks.intuit.com/product/.../small-business-management-software.jsp
Posted on Jul 16, 2010
Cannot receive new password on 2009 Quickbooks
Intuit has an automated recovery tool to remove passwords. search the QuickBooks support site for Password Removal
Nov 07, 2012 | Intuit QuickBooks Pro 2009
UNABLE TO OPEN QUICKBOOKS PRO 2010 I CLICK THE SHORTCUT TO OPEN QUICKBOOKS PRO 2011 AND THE LITTLE LABEL SHOWS SAYING QUICKBOOKS IS OPENING BUT IT SOON GOES AWAY AND QUICKBOOKS DOES NOT OPEN.
This can often indicate damage in the .net framework in windows.
You will probably need to repair the .net frame work, make sure you are logged into windows as an admin, and possibly reinstall quickbooks to resolve this.
Oct 08, 2011 | Intuit QuickBooks Pro 2010 Full Version...
I want to back up a 2nd copy of a quickbooks pro 2006 file but it won't work. When i try and load it from the backup file on my hard drive it says that windows cannot open the file, and to use a program...
You need to make the backup from quickbooks using file,
backup. Select the drive you want the data stored on. Then if you need the backup data you need to use file, restore.
you are only backing up the data so you have to run the
file from the program, with the restored data.
Sep 19, 2017 | Intuit QuickBooks® Pro 2006 Full Version...
Opening QuickBooks Pro 2009
Sounds like your re-installation of QB did not update your registry files properly.
I would suggest:
1) make a backup of your data
2) uninstalling QB
3) delete the QB installation folder entirely
4) re-install QB
5) restore your data
If this doesn't work, I can provide "remote desktop support" to try a more comprehensive approach.
Jan 27, 2010 | Intuit QuickBooks Pro Edition 2009 Full...
Quickbooks 2008 will not load, it says that it is installing and then goes to error 1325
Assuming you have Win XP, please follow these steps:
1. Remove QB from Control Panel>Add/remove programs.
2. First rename all folders of Intuit. rename Intuit to Intuit-old from the following locations.
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then disable your Antivirus / Online Security.
4. Then install quickbooks using quickbooks.msi . You will find quickbooks.msi in the foll location:
>right click on ur QB disc and click open/explore.
>Double click on QBooks folder and run quickbooks.msi and follow the wizard.
If you still get any more issues, please reply with following:
1. Which windows version you are using ?
2. Are you installing QB for the 1st time on this computer?
3. Did you install any other software rrecently ?
P.S : this issue may also be because of Microsoft .NET framework on your computer. PLease help me with your reply to help you.
Feb 19, 2009 | Intuit QuickBooks Pro 2008: Windows
My QB crashes everytime I try to invoice...only with one company, but with others it runs fine. Problem is i need the giles from that one company, What do I do?
You should verify your data file (Click on file, click on utilities, click on verify data) If quickbooks doesn't find any problems, Back up your company to a different location and if your using 2006 or higher, create a portable file, close quickbooks, reopen quickbooks, and then click on open portable. When it prompts you to backup, click ok and back up again using a different file name.
You then need to go to templates, and (sorry to tell you this ) change each one to the default setting (click on lists, click on templates, the click on templates at the bottom, and click on edit, click on additional customization and then default. Then click save and close. Do this for all templates.
Also resort each list (item customer and vendor) to their original order.
Close the file and then reopen and verify data - if this doesn't fix the problem you will need to contact a pro advisor or intuit for aid in fixing the file
Jan 30, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Quickbooks error ~~ transfering files from 2003 to 2009
There may be more than one issue going on here. In some cases, going to a version that is several versions later requires a stepped upgrade. 2003 to 2004, 2004 to 2006, then to 2009. There may also be data damage existing in the 2003 file that will prevent an upgrade, until it is resolved in 2003.
Intuit used to have a policy that it would have you send in a copy of the data file and would convert it for free if you were going to the latest version.
If you are still unable to resolve this, let me know.
Nov 12, 2008 | Intuit QuickBooks Pro 2007 Full Version...
Quickbooks Pro-restoring a back up from a previous version 2005
If is any help - we have just had the same problem.......had version 5 (very old) of QB
changed computer to Vista and would not work so had to buy Pro 208 for Vista . We really had to get in touch with Quickbooks - they send you a free upgrade kit (disc which is Pro 2006 version (not a fuull version but enogh to get the data over) then you load that on your old machine transfer your data to that then copy that again - then load into Pro 2008 - worked fine for us - have come across a hiccup with VAT - but however I guess we are going to have to give in and phone them after the Bank holiday........apart from that everything was fine.
be brave and phone 'em - tech support was helpful.
May 05, 2008 | Intuit QuickBooks Pro 2008: Windows
Quickbooks pro 2005
I got this solution off the official site forums. This worked for me hope it does the same for you guys.
"Thanks for the post. Let me start by apologizing for this. We had sent out a message concerning IE7 and QuickBooks. What is going on is a dialog box is trying to load, but it is not loading completely. Windows is waiting for a response from this dialog box, that can't be seen. What we should be able to do to work around this for now is to press Alt-F4 at the same time. This should force this window that has not loaded correctly to close. Now we should be able to work in QuickBooks without any trouble. If this does not work we may want to hold the CTRL key down while double clicking on the QuickBooks Icon. The first solution I have seen not work only once."
Jan 14, 2008 | Intuit QuickBooks: Pro 2005 for PC
Intuit QuickBooks Premier 2009 Full Version for PC  Logo
154 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
