Question about Mitsubishi WS-65313 65" Rear Projection HDTV
Power light stays, screen is black and no sound
The power light stays on, remote control won't turn off tv. screen is black.
mitsubishi ws-65313
  • 4,889 Answers
Lets try the error code operational check. Press and hold the device and menu buttons for 5 seconds. The LED will blink an error code a series of blinks, half second pause and another series of blinks. Count the blinks before and after the pause and let me know
Posted on Jul 16, 2010
  • 7 more comments
  • gabrielabill Jul 16, 2010
    i see the manue button but what you mean by device.?
    I press the input and menu button at the same time for 5 seconds( front panel, not remote control) and light stays solid green. does not blink.
  • eagle338
    eagle338 Jul 16, 2010
    You should unplug before trying this to reset any previous codes. Otherwise we can test the components of the power supply . I have a service manual that I can give you if you can follow a schematic and have prior experience in handling electronics.
    sure. can i download the manual?
    I unplug the tv and try the codes but still does not blink
  • eagle338
    Click here to download it. LED diagnostics are on page 22.
    microposessor is not working. will not blink at all.
    what's next.
  • eagle338
    Your power supply has failed. That is why the micro processor is not initializing. Since there is no schematic component level repair is gonna be tough. Best thing to do will be to replace the power supply board.
    do you know of a few websites that may sell it?
    thanks
  • eagle338
    eagle338 Jul 17, 2010
    What the power supply assembly? Yes I can look it up for you if you can get me the part number. I will also see if I can find a service manual with schematic so that we can try a component level repair.
Mitsubishi ws-65313 always says tv will turn off in 2 minutes, how do you stop this
It may be the reason they got rid of it but the set should have a hidden menu called Option which will allow a hard reset of the entire set and should cure the quirk the set seems to have==going to need and have the Mitsubishi remote and a four digit number code to do it.
Aug 27, 2012 | Mitsubishi WS-65313 65" Rear Projection...
I have a mitsubishi ws-65313 projection tv i was waching it and went black now its not working the green light is on but tv isnt working and i try to turn it off and the ligth still on i push the botton...
Hi. i believe this to be either of these three problems.
1. Power: it could be that there is a problem with the power electronic element(s). the solution is to go see an engineer.
2. Screen: if the television uses LCD display, it could be a problem with the liquid in it. Solution is to see an engineer.
3. Sleep mode: the TV could be in sleep mode which makes the screen go blank until removed from sleep mode. Solution is to read the TV's users manual to see how to wake a sleeping TV. Get back.
Jul 15, 2011 | Mitsubishi Televison & Video
Is there any way to split the tv in two pieces for
I do not see any way to divide main wooden box of TV as you can remove front screen and back cover of TV but main cabinet of TV still remain the same.
Check below exploded views of WS-65313 for better explanation.
Thanks.
Oct 30, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
WS 65313 Mitsubishi went black all of a sudden
hold down the menu and input buttons after it shuts off it will flash with a code. call tv repair place and they can tell you what code means.
Jun 04, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi Ws -65313 65in
Follow the steps below to reset system defaults to factory settings. . Press the MENU button followed by number buttons , ,and on the remote control. Result: The above steps activate the Reset System Defaults menu screen . Press the ENTER button on the remote control. Result : The settings reset to factory defaults. . Press the HOME or MENU button on the remote control to return to the HOME or MENU screeen. IMPORTANT: This function is not recommended unless it is mandatory to reset system defaults to factory settings. This operation CANNOT be undone and all customs settings will be erased.
If you are unable todo that id suggest you contact Mitsubishi, your dealer, or a local professional.
Main support number 800-332-2119
Support FAX (714) 229-3854
Email supportCustomerCare@meus.mea.com
Mar 30, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Jan 13, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
