Question about Kenmore 22422 Top Load Washer
The washer fills with water but then nothing happens. The washer does not cycle at all.
I had this happen too; the problem was the lid switch. The plastic housing had come apart, either from the lid being slammed down or just normal wear and tear (the washer is 5 years old). Two small screws on the top inside edge and there was enough slack in the wires where I could pull it out to look; I held it together with my hands, pressed the lever and the washer started cycling as usual. Replacing it is a little bit of a pain but better than buying a new washing machine.
Posted on Aug 02, 2010
  • 163 Answers
SOURCE: washer fills up but won't agitate
get your screw driver and lets start.. first unplug the machine from the outlet, you have to access the water level sitch so remove the tab and there is the bandidt, knock him with the screw driver and if this not funcion replace it..good luck I dont tell you to check the thin hose in the water level sitch becouse you said its fill all right.
Posted on Aug 06, 2006
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Maytag Washer Model A606 just quit working. No
The small fuse will prevent water from filling if it is blown. .3 amp
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 10, 2009
  • 47 Answers
SOURCE: I have a kenmore series 70 washer, top loading.
Chack the door swith. Use you finger or a pen to push the switch in asit would if the door (lid) were closed. If there is no switch to push in, it may be broken away but there might be enought left there to see/check and test if that is what needs to be replaced.
Posted on Nov 10, 2009
Fridgeaire washer dryer stack unit. The washer side doesn't complete cycle.
check door lock switch if not water valve for cold side is not on or valve is defective buzzing sound from water valve means not opening
Jun 27, 2016 | Frigidaire Washing Machines
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Jun 10, 2009 | Washing Machines
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Smeg washer/dryer not filling
Check the pressure switch, aka water level switch. If this isn't the problem, it may be the water valve.
Mar 26, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
44 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
