Question about E-Machines eMachines T3830 PC Desktop
My monitor displays power saving mode...i tried the power cable everything is fine still i don't get any display it just says "power saving mode"
  • 86 Answers
Try to remove ur RAM from your CPU and replace it after cleaning it..
It will start displaying
Posted on Jul 16, 2010
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
Sep 21, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
Computer screen goes into "digital power saving mode"
You should be able to adjust the settings on the monitor to prevent it from going into power save mode, or at least to delay how long it takes before it goes into power save mode. Press the menu button and look for settings that might disable or change power save mode.
Also, does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your newer monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PC's video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG L1915S 19" LCD Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Feb 15, 2010 | LG Computers & Internet
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Monitor keeps blank even the power lLED is on green
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Monitor doesn't work
I'd try this monitor on a spare computer. It sounds like the video card (motherboard integrated or otherwise)is not putting out any video information or missing sync signals. The monitor must receive these signals or it will go into standy/sleep mode. If the computer has integrated (on motherboard) video, check your bios settings to see if it is properly enabled. If it has a slot video board, then try a different video board. Your present board might be dead. Another possibility is a bad cable connection. check the connectors for bent pins. Assuming the connector is the standard HDB-15, it is easy to bend a pin over.
May 30, 2007 | LG L1730S 17" LCD Monitor
Analog Power Saving Mode
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
Nov 30, 2006 | LG Flatron L1951S-SN 19" LCD Flat Panel...
E-Machines eMachines T3830 PC Desktop Logo
70 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
