I am trying to load an xp operating system on to hp e-pc 42 computer whose hard drive has been formatted or erased. When I conected the pc to the power supply I get a windows 98 flash screen and then a C:\> prompt but I cannot change the directory to the d:\ to enable me run the xp cd.At the moment I have conneced it to another DELL optiplex gx 270 pc in an attempt to use the network connection for this purpurpose.Please how do I go about this problem?.
    Problem Solver:
  • 95 Answers
Have you tried to boot the computer off the xp cd? It should boot off the cd then give you the install options, just make sure the boot options in bios allow for booting off the cd
Posted on Apr 21, 2008
How to format for windows xp
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios.
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system.
Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd\dvd.
Aug 15, 2013 | Computers & Internet
How do i format a sata11 hard for use in another pc in windows xp pro 32 bit
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
hope this helps
Jul 12, 2012 | Western Digital Caviar Computers &...
I have a NC6000 whose hard drive stopped working and I replaced the hard drive and I could not get the software to load. I replaced the motherboard and now it will load but it still is not loading al
hi,
please check whether the hard drive is loaded properly into the computer.Turn on the compupter try to go to the bios of the computer and there do the harddrive long test.if the test is failed then the harddrive has gone bad.if the test is passed then try to install the operating system with a recovery cd's.if you don't have the recovery cd's then you need to call HP to get the recovery cd's.
Nov 15, 2011 | HP Compaq nc6000 Notebook
Can we format pc by usb drive
you have to format your hard drive using a third party disc to erase everything on your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note after you have loaded the operating system you should go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
if you need more help with this post a reply
hope this helps
Aug 24, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
HOW CAN I FORMAT A 250 HITACHI HARD DRIVE WHEN IT WOULDN'T LET ME
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
or if you are trying to format a usb drive
insert your pen drive
click start click on my computer you should see your pen drive
Feb 17, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
The volume is busy...
Hello sparkling202,
• Goto http://www.bootdisk.com/
• Select Windows XP Fresh Install Bootdisk And Bootable CD
(You should be able to format the hd from the bootable cd)
*As a reminder, The format command will ERASE ALL YOUR DATA on the hard drive !
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | HP dx2250 Monitor Personal computer AMD...
Hp pavillion ze 4300 will not boot past windows (blue w. icon) screen if i load from windows xp cd will this erase hard drive?
what operating system are u using currently?......if u r using win Xp it will not erase hard disc....load the cd and select repair.
Nov 11, 2009 | HP Pavilion ze2000 Notebook
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
HP Compaq Notebook nx9010
Hi, I can help you with this. What operating system are you trying to load?
Sep 27, 2007 | HP Compaq Business Notebook NX9010
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
