Question about Rio Carbon MP3 Player
Fixing volumn wheel
Got the face plate off but can't get the back off. Can't seem to get it to release. I see the two slots on the bottom of the front but when I insert a tiny screw driver into the slots nothing happens. Any ideas on how to get the back off?
    Guru:
  • 155 Answers
If you pry a small screwdriver round the side you will see 2 clips inside attached onto a black bit (the hard drive holder) there are also 2 smaller ones near the top and 2 at the bottom but you will only have to unclip a few before the back comes off. To unclip them simply put your screwdriver below and lever off your rio and they should pop up... I have taken the back off many times and fixed my volume control and hard drive... Fixing the volume control is quite easy. Once you take the back off you will be able to see where it locates on, then you can just stick it back on with a bit of super glue etc.
Hope this helps
Mowcius
Posted on May 13, 2008
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
Just installed an XDM7615 Dual stereo and the face plate won't detach. Can anyone help? The manual says there is a button behind the face when it's in the 'eject' position but pushing this button does...
There are 2 very small screws on the back of the face plate that need to be removed. Once these are removed, you may then remove the face plate.
Feb 10, 2010 | Car Audio & Video
Install CDrom hardware
There are several Gateway case models. I think most of them you have to take the side panels off and the face hss some pins or straps that enter the inside of the case through the front of the computer and latch into the main case. Once you remove the sides then you can see them on all four corners. You just need to put the outward pressure on the housing face and then push the latch to the side with a screwdriver to release them.
Nov 23, 2009 | Computers & Internet
Where is the wireless switch?
It is located on the front edge of the laptop, below the indicator LED's and left of the volumn knob and audio jacks.
Oct 26, 2009 | Toshiba Satellite Pro L300 Notebook
Broken Volume Wheel
replaytv.com is the new location of Rio Carbon
Mar 12, 2006 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
