Question about Royal Sovereign ARP-1008 Portable Air Conditioner
Why is my portable air conditioner arp 1000es leaking water onto the floor
  • 86 Answers
SOURCE: water leaking all over
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Posted on Jul 25, 2009
james3751
  • 614 Answers
SOURCE: My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Posted on Jul 26, 2009
  • 615 Answers
SOURCE: A red light came on and the unit turned off
see if you can push water from the other end to see if you have something that stuck inside
Posted on Sep 08, 2009
madman775
  • 5 Answers
SOURCE: leaking unit
check to ensure that the drain hose is not touching the side if the water storage bin. if still no luck then watch unit when running to assess the leak point............maybe a hairline crack in water container
Posted on Nov 02, 2009
  • 74 Answers
SOURCE: I have a Royal Sovereign
High humidity - keep doors and windows closed as much as possible to eliminate introducing humidity.
Posted on Sep 23, 2010
I have Royal Sovereign ARP-1000ES Portable Air Conditioner. Last a few days, it shut off When running with cool mode.(no problem with dehumidify or fan mode) I checked water tank, but it's empty. Please...
It is supposed to shut off when the room meets the temperature you set it for. Are you saying it shuts off before the room cools to the temp you set it for?
What do you mean "..last a few days...?" Is it new only a few days and then break?
Be clearer if you need help.
Oct 18, 2013 | Heating & Cooling
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
Window kit for RS ARP-9411
I assume you are looking for the window kit for ARP-9411 Portable Air Conditioner. If so, contact
Royal Sovereign Customer Support 1-800-397-1025 .
Hope this helps you & thanks for choosing FixYa.
Aug 19, 2011 | Royal Sovereign ARP-1000EX Portable Air...
Water leaking from beneath unit. Some water enter buckets some leaking onto floor. Can't use the unit it leaks so much.
Look for the drain tube which sends the water to the buckets. It may be disconnected or misaligned allowing the water to go the wrong way. The tube can also be stopped up. Blow through it to clear.
Jul 22, 2011 | Danby Portable Air Conditioner
My unit is leaking tons of water only when a/c is on for a while. It leaks out of base and I have to drain tank every day. Help!!!
It is supposed to "leak" water into it's reservoir and it needs to be dumped when it gets full. That water is the humidity that the a/c is pulling form the air inside your home. As long as it's going into the reservoir and not leaking onto your floor then it is working properly.
Jun 24, 2011 | Windchaser PACR10 Portable Air Conditioner
Sep 08, 2009 | Royal Sovereign ARP-1008 Portable Air...
Constant leaking water
The unit must be level and the hose lower than the machine. -Good Luck-Ned_
Aug 23, 2009 | Frigidaire FAP094P1Z Portable Air...
Jul 26, 2009 | Pelonis KCD-25YI Air Conditioner
Royal Sovereign ARP-1008 Portable Air Conditioner Logo
192 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
