Question about Yard Machines Garden
I have to put gas directly into carb for it to run,
I have or get white fluid at top of tube coming from engine. Also have to put gas directly into carb for it to run. The white fluid doesnt show up all the time.
  • 755 Answers
What you have is a very very wet climate! The engine is pushing the water out when you run it and it mixes with oil to become white and milky. As long as you change your oil every 25 hrs or so this shouldnt be a big problem. This wet condition is probably why you have to prime it by hand to start it as well. You need to remove the carbs bowl *(located on the bottom of the carb. It usually takes a half inch wrench to remove the bolt *(also the main jet) from the bowl.
Gently lower the bowl with your finger covering the hole where the bolt goes through so you can look at the fuel and see if you spot any water droplets in the fuel. Severe water will be a pool in the bottom of the bowl. You can then dump the fuel and look for water drops again.
If you find water in the fuel you should empty the entire fuel system and let it dry out. You can then put the bowl back on the carb and refill with fresh gas. Be sure the empty and dry your gas can too. They also accumulate water!
When this is all done. You might consider storing your mower higher off the ground or in a cool dry place.
Good luck and be careful!
Posted on Jul 16, 2010
Mitsubishi MGE 5800 generator won't start. Will run for seconds when I put gas directly in the carburetor. I cleaned the carburetor etc.
If the engine will start when starter fluid is sprayed into the carb, you missed cleaning some small orifice in the carb. Recheck/reclean the carb and you should be OK.
Aug 18, 2017 | NEC Mitsubishi MGE 4000 Generator ROU...
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Where do I spray the starter fluid (air intake?) for Chrysler Silhouette. Ran out of gas and it seems carburetor needs starter fluid to kick it..not sure where air intake is locater.. or where to open carb...
there is a large tube that goes to your throttle body (you do not have a carb), remove it and spray there-be careful, starter fluid is highly explosive, spray 2 or 3 short bursts into the top of the throttle body opening, and install the tube (you don't have to tighten the clamp). You may have to repeat this a few times, if you can only get the car to run for a few seconds 3 or 4 times, and it will not run on it's own, you have a fuel delivery problem, and no amount of starter fluid is going to fix it.
Dec 28, 2010 | 1994 Oldsmobile Silhouette
I have a 8hp briggs and stratton model 190432 with a carb 390323 that gas just pours out the bottom can anyone help?
I had the same problem with my 190402 tiller engine (on a 1978 Sears RT-8 that my brother gave me). The carb leaked like crazy when I got the tiller, so I rebuilt the carb. Bought a new float, but the old one was fine (the hot water test you can read about if you do a Google search).
After rebuilding the carb and checking the float system (carb apart, hold carb top upside down with the float and needle installed, then blow into the gas inlet to see if you can pass some air. My carb top passed that test, and I guess it's a valid test. Never tried that one before . . .
Put the engine back together, and the carb leaked gas fairly steadily, but at a much lower rate.
I read a comment from someone that sounded flat-out wrong, but the Briggs rep. who responded to my email said to do the same thing. In fact, the rep. sent me a Briggs document showing what to do. It's like a tech sheet. Nice customer service (and I never even bought their stuff directly!!).
The problem I had was with the emulsion tube and its seat inside the carb. You probably have the same problem. You need to buy a new one emulsion tube because you are going to ruin the old one. The tube seats against the carb at a place that is below the fuel level -- can you see the problem?
Take the old tube, grind off the threads (I used my Dremel tool). Get some lapping compound (I used water-based stuff from the local auto parts place). Put some compound on the seating part of the tube, insert the tube, and use a screwdriver to lap the tube against the carb seat. Check it every once in a while. I think I probably did it for 3 to 5 minutes, not very aggressively, and added compound one time.
Look for a smoothness to the carb seat. Thoroughly clean out the carb. I used spray carb cleaner for the initial rebuild and the lapping compound clean-up. Put the carb back together and check for leaks before starting the engine. Start the engine, and hope that the leak stays gone.
I haven't had any problems yet, and I've used the tiller for about 4 to 5 hours so far. Maybe 6 or 7, but I've been using it for about a month off and on.
If you want me to send the pdf version of Briggs' document regarding this fix, send an email to me at jsanfellipo@donobi.net. Just put in the subject line: Briggs Carb Fix. I'll shoot you a copy no problem.
Good luck.
John
Apr 03, 2010 | Air Tools & Compressors
Having problem starting and keeping engine running. Spray engine starter fluid and runs for couple of minutes then dies. Acts as if its not getting fuel. It is a 13.5 briggs and stratton engine. Could it...
some have fuel filter some do not , but it sounds like you have contaminated fuel and is is clogging up fuel line or carburetor,look into gas tank with a flash light and see if there are specs floating at bottom of the tank, if there are drain tank of all gas and remove tank and flush it out with brake cleaner, then disconnect both ends of fuel line and spray through tube into white paper towel until u see no dirt/debris. then remove air filter clean foam( soapy water, dry re-oil 10w30 is ok). remove carb from engine spray through main port with carb cleaner not brake cleaner, and use tube and spray through inlet tube while holding throttle wide open reassemble and it should run fine, if not u may need to disassemble carb if not comfortable with this then order new one usually under $100
Jul 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
74' TX500, High idle and White smoke from breather tube
When the carb was rebuilt it was only bench tuned. It is always wise to tune them once installed. the smoke may stop after the carbs are adjusted. However white or light colored smoke is always an indication of oil. It sounds like you may have a small leak. Hope this helps. Good luck.
Jun 11, 2009 | 2003 Yamaha YZ 250 F
Engine will crank but will not turn over
Do this, take the top off the carb, being careful not to damage the gasket. Then take some carb cleaner and clean out the bowl and floats. Remove the needle valve and clean it out. Put it all back together and filling the bowl with carb cleaner. Start it with the starting fluid. Once you run the carb cleaner through it, it should start to run on it's own. Whatever you do don't shut it off for about 20-30 min unless you have to.
Apr 27, 2009 | 1989 Jeep Wrangler
Lawnmower starts when primed only then stops
You take the air filter off from carberator (three bolts). There is a bowl with a nut underneath. With socket wrench take bolt off and remove bowl. there are some small holes on the bolt and carberator. Take a twisty tie, like to tie up garbage bags, and run the wire in and out of the small holes. Spray a bit of carb cleaner for good measure.
Put it all back together but don't forget the gasket between the carb and the filter assembly.
Apr 15, 2009 | Garden
Gas leaking from hose that is under tank that is not for gas flow
is it an overflow from the carb? gas will only be in one of 2 tubes and they are the fuel line from the tank and the carb over flow. unless you have an electronic fuel pump then tubes go from tank to pump to carb. if its coming from the overflow then you are getting too much fuel into the carb float chamber. you may have a sticky float. thy getting some Berrymans B12 fuel additive and putting double the doseage in the tank. run engine til hot then leave it to stand overnight. this should break down any gum/varnish that has built up in the system
has this been in storage thru winter?
Apr 02, 2009 | 2001 Honda XR 250 R
Garden Logo
90 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
