Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 82V522
I cant find a reset button
I cant find my reset buttonon my rheem 82v52-2
  • 349 Answers
Reset button is on the top thermostat which is located behind the top access panel taht is removal. It will have a screw in it to remove and behind the insulation will be the thermostat..
Posted on Jul 17, 2010
What is causing electric tankless hot water heater to be needing red button reset often?
PDF]Tankless Electric (RTE) Troubleshooting - Rheem
www.rheem.com/docs/FetchDocument.aspx?ID=87d15e35-5adf-4e9f...
Tankless Electric (RTE) Troubleshooting. Technical Competence .... For four chamber units (RTE18 & 27) go to paragraph 4T. 9. Conduct OHMS resistance ...
Rheem RTE 27 Series ' Use and Care Manual
https://www.manualowl.com/m/Rheem/RTE-27-Series/Manual/296033
Rheem RTE 27 Series ' Use and Care Manual - Page 1. Use & Care Manual Electric Tankless With Installation Instructions for the Installer Water Heaters The ...
Sep 06, 2015 | Rheem RTE 27 Tankless Electric Water...
Please help!! I can't find the reset button on my Rheem 81V52D C model water tank! I opened the top panel and didn't see a red reset button. Totally confused now. Please help?
if there is no reset button, you should be able to turn the breaker off for a few minutes. then turn it back on. if its an electric water heater! it should reset it. good-day !
Mar 26, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Where is the reset button located on my Rheem Warrior Class Model # 71-522D
Question posted under Rheem electric water heater.
1) ECO red reset button is on upper thermostat, located under upper cover on side of tank.
It is covered with insulation. See images:
http://waterheatertimer.org/images/water-heater-thermostat2.jpg
http://waterheatertimer.org/images/Jly-022-thermostat2-175.jpg
2) Be sure to put cover and insulation back in place after pushing in reset button.
3) Push button inward very firm.
4) If reset does not punch back in, then replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Open following link for full troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Indoor tankless 74-pvn. power went off and has returned. get error code 24 when try to power on
Open following links for Rheem troubleshooting resources, including Rheem chat, error codes, and possible manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error codes are considered start-point for troubleshoot.
Error code 24 is malfunction of operational switch: press max or min button on PC board to reset, -or- replace PC board.
Max-min button is sometimes located above dip switches, and can be 1 button that is rotated with screwdriver or 2 separate buttons. Look at wiring diagram in manual that came with product.
Fix most tankless problems yourself, same day, for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 14, 2011 | Rheem Tankless Hot Water Heater...
I'M NOT GETTING HOT WATER THE SYSTEM HAS POWER IS THERE A RESET BUTTON OR OL SWITCH ON A RHEEM TALL ELEC UNIT
There is a reset button located behind the top cover plate on the side. Remove four screws to remove cover and carefully spread insulation apart to access element,thermostat, and reset button. It is a small round red button. If you push it in and it stays thens the element should come on. If it pops right back out then you need to look at changing the reset.Thank you.
Mar 29, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Bosch 10p, the pilot light went out, when reigniting i pressed the shut off button, now it is locked in and i cant release it, is there a reset button somewhere? regards
Bosch Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
For Bosch tankless troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For Rheem tankless resources:
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Mar 28, 2011 | Bosch & Tankless LP Hot Water Heater
Water heater not working
Check the top thermostat... right above it is a red button that you will have push hard on to reset...
If all that checks out then you have a bad top element...replace that...
heatman101
Apr 24, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The control unit needs to be reset when I loose power
have two boilers one a rheem the other raypak, the raypak keeps turing off i have to push the reset button. what could be wrong
Dec 30, 2009 | Rheem Paloma Tankless Water Heaters...
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 82V522 Logo
663 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
