Question about Dell ST2010 20" Monitor
My 20 inch dell monitor is only using the left corner the screen and you can only see part of the desktop is visable and the text is upside down.
    Genius:
  • 1,970 Answers
Mcdevito75 here, Press the AUTO button on your monitor, if this does not work, press the MENU button, there you should see a square box with 4 arrows, these are used to center your picture on your monitor, use the left / right arrows also on your monitor to adust the screen picture with this box woth the 4 arrows from Menu.
Posted on Jul 16, 2010
Why would everything on my laptop screen be upside down
Hi.
You may have accidentally hit a sequence of keys and now your Windows screen is upside down.
Press Ctrl + Alt + arrow (left, right, up or down) to rotate the screen to the correct way.
Regards.
Dec 07, 2011 | Dell Inspiron B130 Notebook
I have a Dell Inspiron 531S, I have both two different monitor slot, does my PC support dual monitor systems?
Yes.
The area on the back of the computer, that has two ports to connect a monitor, is a Graphics Card.
It is a PCI-Express graphics card, and is plugged into a PCI-Express x16 slot on the motherboard.
(Expansion Slot)
It has a blue VGA port, white DVI port, and black S-Video port.
The area on the upper left with a blue outline around a VGA port, is a VGA port connected directly to the motherboard. It is Integrated Graphics.
You CANNOT use Integrated Graphics, and a graphics card at the same time.
It's either use the Integrated Graphics VGA port, OR use the graphics port/s on the graphics card.
BIOS will Not support using both Integrated Graphics, and a graphics card.
HOWEVER, you can use the VGA port, and the DVI port when using two monitors.
You will be only using just the graphics card.
Example of a VGA port, (Connector), and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI port, and DVI cable,
http://en.wikipedia.org/wiki/DVI_connector
1) Whatever monitor you have that has a VGA cable, plug it into the blue VGA port on the graphics card.
(There are VGA monitors {CRT} that resemble a small TV. VGA cable is usually attached.
There are also LCD flat screens that have a VGA connector, for a VGA cable, and may also have both a VGA, and a DVI connector.
To digress for a moment;
VGA is Analog. It uses an Analog video signal.
DVI is digital. It uses a Digital video signal.
A computer naturally puts out a digital video signal. This digital signal has to be converted by the computer, into analog for an analog monitor. This slows the graphics process down. This is one reason it is best to use digital )
2) Plug a monitor with a DVI cable into the white DVI port on the graphics card.
3) Turn the monitors on.
4) Turn the Inspiron 531s on.
5) When Windows has loaded, right-click on an empty area of your desktop computer screen.
Now left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
6) You are now looking at a small window that has two monitor icons in it.
Monitor 1 icon, and monitor 2 icon.
Monitor 1 icon is your Primary Display.
Monitor 2 icon will be for the Secondary Display you are adding.
Note how monitor 1 icon is sitting to the Left, and monitor icon 2 is sitting to the Right.
This is how your monitors are supposed to be arranged on your computer desk.
If the second monitor is on the Left on your computer desk, you need to move the icons around.
Move monitor 2 icon to the Left.
Left-click on the icon, hold the left mouse key down, and drag the monitor 2 icon over to the left side of monitor 1 icon. (All the way over, or it will snap back to where it was)
It may matter to you how your monitors are arranged. It may not. Once you read the following it may help you decide.
7) Left-click on monitor icon 2 if you have not already done so.
Go down to where it states, "Extend my Windows desktop onto this monitor"
8) Left-click once in the empty square, to the left of Extend my Windows desktop onto this monitor.
9) Now left-click on Apply at the bottom Right corner.
10) Finally left-click on OK at the bottom Left corner.
You should now see your desktop screen on both monitors.
When using the internet on both monitors, you have to drag the screen from the Primary monitor to the Secondary monitor.
Go to the left side of the screen. Left-click right on the edge of the blue frame. Hold the left mouse key down after you click, and drag the screen across to the left.
Doesn't work?
Go to the right side, click on the blue frame, and drag the screen to the right.
This is why it may matter how the monitors are arranged on your computer desk.
It's kind of eerie your first time dragging the screen across.
You will also find out why it is best to use two similar monitors, when using dual monitors. The pixel resolution is different for both monitors, if they are different from each other.
For additional questions please post in a Comment.
Regards,
joecoolvette
Just to add:
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
I have a Dell monitor that is showing my screen upside down??????? HELP
Hold down Ctrl and Alt and use the cursor keys to rotate the display back to how it used to be.
Regards.
Jul 05, 2010 | Dell Inspiron 530s Desktop Computer
Text is upside down, how do you trun the screen 180 degrees?
Right click on an empty spot on the desktop, scroll down to the video control panel, may be Nvidia or ATI. Look in the left pane for an entry that states, "screen orientation" or "rotate screen". set the degrees to zero or follow the illustrated view and hit apply or ok.
Jan 12, 2010 | Computers & Internet
Someone just gave me a imac desktop its a 2006 model.The person that was bringing it to me some how cracked the inside of the monitor when the computers off everything looks ok but when you turn it on you...
Well... your LCD is broken is the issue. The price depends on the size of the display. I suggest looking on the internet for the screen inside your monitor. A raw screen can be bought to replace the one that was broken for around $80.00 for the 17 inch ones I see on a quick search. Yours might have a 20 inch or 19.. I am not sure for your 2006.. The raw screen is available though as a trade-in. They will replace your glass screen and refurbish to resell. Do you know the size of your screen by chance? You have to measure diagonally corner to corner of the part you look at to know... I would expect to dish out from $80 to $150 ballpark. I did a 14 inch dell PC monitor for about $40. the price of LCDS is coming down so much it might be cheaper and better to replace the whole monitor.. just have to compare prices though. Hope that helps.
thanks!
Stan Skaggs
Oct 19, 2009 | Apple iMac G4 Desktop
When I move the mouse off the side of the screen
Try changing the screen resolution of your screen
Aug 19, 2009 | Apple Computers & Internet
My DELL Monitor shows the picture upside down
Try holding down the CTRL key + ALT key and tap on the Up arrow key once to rotate the display back to orginal orientation
Thanks
proton
Mar 22, 2009 | Dell E193FP 19" LCD Monitor
Yesterday, when I powered up my laptop, everything was all of a sudden enlarged ( the desktp, icons, internet, text, e-mails, EVERYTHING). I know this is probably supposed to be some kind of useful tool...
Your enlarged desktop could be caused by several different things, so I will address each one in the order of likelihood of each one:
1. You may have accidentally changed your Display Settings.
Right-click on your desktop and select Personalize. Scroll down and click on Display Settings. Ensure that your Monitor Resolution is set for the maximum. If not, use your mouse to move the slider bar all the way to the right.
2. You may have accidentally changed the size of text and icons.
Right-click on your desktop and select Personalize. In the bottom left-hand corner, select Ease of Access. About half way down the screen, select Make the computer easier to see. Click on Change the size of text and icons about half way down the screen. If it is not selected, chose the default scale.
3. You may have accidentally turned on the Magnifier.
Right-click on your desktop and select Personalize. In the bottom left-hand corner, select Ease of Access. About half way down the screen, select Make the computer easier to see. About half way down the screen, uncheck the Turn on Magnifier.
To turn off the On-Screen Keyboard on start-up,
right-click on your desktop and select Personalize. In the bottom left-hand corner, select Ease of Access. About half way down, select Use the computer without a mouse or keyboard. Unselect Use On-Screen Keyboard.
To turn off the Narrator on start-up, right-click on your desktop and select Personalize. In the bottom left-hand corner, select Ease of Access. About a third of the way down, select Use the computer without a display. Unselect Turn on Narrator.
I hope this helps. If so, please remember to rate my post.
Thanks!
Jul 27, 2008 | HP Computers & Internet
Monitor
Ctrl,Alt and the arrow up, down key should fix it. Check your pc because some use a different key code. If no right click on desktop, go to properties, display settings and adjust the screen.
Jul 06, 2008 | Dell Dimension 3100 PC Desktop
Dell ST2010 20" Monitor Logo
129 people viewed this question
Alun Cox
