Question about Microsoft Windows XP Professional
Windows system32 autoexec.nt fail to operate
System32 not suitable for dos or windows
    Guru:
  • 195 Answers
Win XP SP2: System not suitable for running MS-DOS. ... This file is part of the Windows 16-bit subsystem and usually lives in the system32 folder. ... P.S. If this doesn't work check out the Microsoft web page for additional fixes. ... Computer Tips Daily - Run your Windows PC like a pro! No matter what your skill ...
www.worldstart.com/tips/tips.php/1453
Posted on Jul 16, 2010
What is the mean auto exe c bat in dos files??
An AUTOEXEC.BAT file contains MS-DOS commands which are executed automatically when a Personal Computer boots. This file is usually located in the root directory of the hard drive or floppy from which the computer boots (or starts) up. The AUTOEXEC.BAT file is used to set various default settings and to run programs that should be executed upon startup. Below you will find a list of executable statements (commands) that typically go into an AUTOEXEC.BAT file, along with explanations their.
The AUTOEXEC.BAT file is one form of a batch file, and it is used to automate functions in MS-DOS. In their simplest form, batch files contain MS-DOS commands (batch file language) which includes commands for such things as loops and execution branches and the like.
ECHO
Example: @ECHO OFF
This optional command will suppress the display of subsequent commands while the AUTOEXEC.BAT file is being executed
Dec 09, 2010 | Computers & Internet
Virtual device driver format in the registry is invalid
Windows XP instructions:
  1. Click Start->Run and type Regedit. Click OK
  2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\VirtualDeviceDrivers
  3. Delete the VDD value
  4. Click Edit->New->Multi-String Value
  5. Name the value VDD, press Enter
Windows 2000 instructions:
With Windows 2000 you must use regedt32.exe instead of regedit.exe. The regular regedit will not allow you to add REG_MULTI_SZ's for some odd reason and a regular string value will not work in this instance.
Aside from that, the instructions are the same.
It also may be necessary to extract the original autoexec.nt and config.nt from your Windows CD, as they may be corrupted.
  1. Click Start->Run and type expand x:\I386\autoexec.nt_ %systemroot%\System32\autoexec.nt (Where x: is your CD-ROM drive)
  2. Click Start->Run and type expand x:\I386\config.nt_ %systemroot%\System32\config.nt
  3. Click Start->Run and type expand x:\I386\command.co_ %systemroot%\System32\command.com
Jan 29, 2010 | Computers & Internet
I can't install a visual basic 6.0. because I've been accidentally deleted the some components of system32. most especially the config.nt
If my memory serves, VB 6 was the last dos/windows version and windows;nt was simply a text file that held some config parameters when it ran in nt mode. I woud suggest you update your software, but if you are unable to do that, you might try reloading nt from diskette or CD. I think NT also supported the undelete command. If it hasn't been very long since you erased it, you may be able to restore it with an undelete. I think that was the command name.
Dec 11, 2009 | Microsoft Windows XP Home Edition
I recently had a HD crash and have replaced it with another HD using the same Windows XP OS. While trying to reload programs that were on the old HD to the replacement, some of the programs get this error...
I always receive a "C:\WINDOWS\SYSTEM32\AUTOEXEC.NT" error message.
“C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-
DOS and Microsoft Windows applications. Choose ‘Close’ to terminate the application.”
This error message is not caused by the installation CD-ROM, but rather by the
“Autoexec.nt” system file. Windows is unable to find this file when launching the
installation CD-ROM, the file most likely having been deleted by another application.
To resolve this problem, proceed as follows:
1. Go to “C:\Windows\repair” and find the file “Autoexec.nt”.
2.Copy this file to “C:\Windows\system32”.
3.Right-click the file “Autoexec.nt” that you have just copied, and select
“Properties”.
4.Tick the “Read-only” box and then click “OK”.
Aug 06, 2009 | Microsoft Windows XP Professional SP2 Full...
My cmd command never run, there is volume problem, I think mother board board problem is there what i do?
try to ran it from
c:\windows\system32\ cmd.exe
rightclick on it and select run as.
if its not working from there then in that case your system profile may be corrupted.In that case you need to reinstall windows.
Apr 13, 2009 | Intel D845GVSR Motherboard
Old DOS program in WIN XP
hello sir
i have f500 compaq laptop i have no winxp driver in sound driver plz help me
thanks
Aug 31, 2008 | Microsoft Windows XP Professional With...
Regestry editor
A central hierarchical database used in Microsoft Windows 98, Windows CE, Windows NT, and Windows 2000 used to store information that is necessary to configure the system for one or more users, applications and hardware devices.
The Registry contains information that Windows continually references during operation, such as profiles for each user, the applications installed on the computer and the types of documents that each can create, property sheet settings for folders and application icons, what hardware exists on the system, and the ports that are being used.
The Registry replaces most of the text-based .ini files that are used in Windows 3.x and MS-DOS configuration files, such as the Autoexec.bat and Config.sys. Although the Registry is common to several Windows operating systems, there are some differences among them.A registry hive is a group of keys, subkeys, and values in the registry that has a set of supporting files that contain backups of its data. The supporting files for all hives except HKEY_CURRENT_USER are in the %SystemRoot%\System32\Config folder on Windows NT 4.0, Windows 2000, Windows XP, Windows Server 2003, and Windows Vista. The supporting files for HKEY_CURRENT_USER are in the %SystemRoot%\Profiles\Username folder. The file name extensions of the files in these folders indicate the type of data that they contain. Also, the lack of an extension may sometimes indicate the type of data that they contain.
Jun 20, 2008 | Microsoft Windows Vista Ultimate Edition
Internet for ps2
Autoexec.bat and config.sys help and instructions ... Windows 2000, Windows XP, or later operating systems. However, in some cases it may still be necessary for users to edit or configure these files.
Configuring a modem in MS-DOS Information and help for configuring a modem in MS-DOS.
How to enable automatic logon in Windows NT / 2000. To configure Windows NT / 2000 to automatically login will require the registry to be edited and the following instructions to be done.
Good Luck, please dont for get to Vote/Thank You.
Dec 22, 2007 | Westell Wirespeed LiteLine 6100...
Lesmcark z52
Try this and see what happens(I'm under the assumption that you are running Windows XP): Click on start -> Run Type "cmd" then press enter At the prompt type: "cd \" then enter "cd windows\repair" then enter "copy autoexec.nt c:\windows\system32" then enter Press y at the overwrite prompt. Try loading the cd again and see what happens!! Regards, Armando
Apr 23, 2007 | Lexmark Color JetPrinter Z52 InkJet
Microsoft Windows XP Professional Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
