Question about Fisher and Paykel GWL11 Top Load Washer
The washing machine stopped during the rinse cycle and only produced a low humming sound. The pump appears to have stopped working. I need information on how to determine if the pump needs replacing and if so how to repair this problem myself.
  • Anonymous Mar 30, 2014
    smells and stops during rinse cycle
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now is the machine draining ?If not bail some of the water out with a pot or small bucket just enough so you can tip the machine back so you can look underneath the machine without it leaking everywhere.Now when you are looking under the machine look to the front right and you should see a red or black fan.This is your pump.Turn the fan clockwise and anticlockwise a few times to loosen the pump if it is jammed.The fan should turn freely.If it turns freely after turning the fan put the machine back on its feet and select a spin cycle and push the start button.Hopefully the machine will start to drain.Please reply on how you got on or if it still does not drain or if you have the newer type of pump.Good luck.
Posted on Jul 17, 2010
  • KangarooTott Jul 18, 2010
    We had a similar issue: macvhine washed, but would not spin or drain. Machine cycled water in, as if it were about to spin, but lid never locked and spin cycle never kicked in. Diagnostic test indicated drain pump is blocked. We tried this solution, and it worked - while the machine was empty. As soon as we put clothes in it, the problem recurred. We have now bailed the machine out 4 times and are at our wits end. Any other suggestions?
  • KangarooTott Jul 19, 2010
    After posting comment below, we experimented further. It appears our problem may be different: after trying the solution below again, while empty, the machine did spin, but the water did not drain out, after an initial few second spirt. We put two items in, to confirm the machine was actually spinning. It was, but this time, no water was removed. Any ideas?
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
My washing machine stops working when it goes into the rinse cycle. It just makes a humming sound coming from the dial.
does it pump out the water first if not suspect lid switch..also ck to be sure cold water is getting through valve ckd cold inlet screen in fill valve most washers use a cold only rinse
Jul 09, 2008 | Washing Machines
Noise during wash and rinse cycles
Got a response from another site - the noise was due to the recirculation pump (situated low down at the back on the other side from the drain hose) which was working, but clogged with a nasty grey 'porridge' of limescale and powder residue in the pipes either side of it. Dismantled, cleaned out pipes and ran a wash cycle to clear any remaining crud out. Seems ok now and wash jet working, noise gone.
Mar 28, 2008 | Zanussi WJD1457W Front Load Washer / Dryer
Aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
232 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
