HI How r u? I have this LG 42pg3000 model: No picture No sound ONly on/off button with power green light. Any help what is wrong with it? Look forward 2 ur early reply. Thanks.
  • 1stopman Jul 19, 2010
    HI how r u?
    I have this LG 42PG3000 stuck/dead with green light lit on on/off button.
    Check/test fuses they are ok.
    Relay click and still the same.
    Then whielle waiting checked other resistors and found 2 x R270 open circuit.
    Replaced them and tried ....now relay clicks all the time and still no functions of any button or on/off switch....
    Can u help me plz?
    Thanks
  • 666 Answers
The blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Posted on Jul 19, 2010
    Hi
    U miss understood me .
    Ligh light is NOT blinking.
    The relay would come on once before i Had replaced 2 resistors (R270)
    Now the fault is the replay i clicking all the time and still no operations on any button.
    Hope 2 hear from u soon.
    bye 4 now
  • Televison & ... Master
  • 2,005 Answers
Remove power, remove the back, look on the circuit boards for anything that says F1,F2 etc. these are fuses test them with a multimeter replace any bad ones.
Posted on Jul 16, 2010
  • 1 more comment
  • 1stopman Jul 16, 2010
    Hi there.
    I have tested both fuses ..all ok Fs1 on power supply board and other fs2 on secondary board.
    any further help plz?
    Thanks
  • Jim Goldsmith
    Jim Goldsmith Jul 16, 2010
    when you turn the set on and, off do you hear a soft click? if you do not; the power relay is at fault if it does click a section of your power supply is at fault.
    Hi
    When plugged the relay clicks and green light comes on off/on buttonand stays on (green) but there is no operations of on/off button when pressed neither from any other buttons(channle+- or volume +- etc).screen no lit.
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
Hi , i have a problem with a plasma LG 42PX3RVA, the set turns green when you press the power button but no picture or sound , i measure the voltage on the boards and found thay it was correct acco
Bulb overheated and probably blew, they are made of mercury most times so don't touch them they should be in a housing, that could be it. If most times dust gets in there and the fan gets weighted down with dust if its up against the wall no air flow, so there ya go, try that. good luck
Jun 02, 2014 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Standby light changes from red to green
hi this fault could be down to capacitor in the power supply, they bulge or go leaky, you need to take the back off the tv, to have a look. try and find a tv tech in your area hope it helps
regards
shaun
Jan 05, 2014 | LG 42PX5D 42 in. Plasma HDTV
Digital lifestyles model fa2b 32570
Could be a couple of things.
The good news is that the LCD panel is working, albeit briefly.
It definitely sounds like it's repairable, though.
Dec 03, 2013 | Televison & Video
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
Jan 27, 2018 | LG Televison & Video
No picture no sound
seems to be common faults with this model in LG there have been a number of their models recalled to fix power board and the video controllers
Aug 19, 2009 | LG 47LC7DF 47 in. LCD HDTV
LG 50PG3000 SOUND BUT NO PICTURE
This sounds like a screen problem, possibly the internal connecting cable (LVDS) which connects from the main board to the screen may have become loose. If not a replacement screen would be required.
Jun 29, 2009 | LG 50PG30 Plasma HDTV
My LG 42pg3000 stopped displaying hdmi inputs.
I have a similar issue. HDM1 does the same thing, did you ever find a solution?
JP
Apr 05, 2009 | LG Televison & Video
Televison & Video Logo
320 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
