OSD screen lock
Hi Mark,
I am new in servicing LCD.
I would to which area located the osd . Either Inverter board or logic board?
Tia.
  • Ajemy  Rashid
    Ajemy Rashid Apr 21, 2008
    Hi Mark,
    Thank you very much upon your helps.May god bless you upon helping others.
  • 472 Answers
The OSD is controlled by the video card board (logic board)
It is information stored on the eprom, not something you can just get to. It has to be programmed.
To gain access to the OSD Service Menu from a user service point you normally access it via a series of buttons on the control panel. Holding several buttons at once in a set combination that is particular to that brand, or even that individual series of monitor.
OSD just means "On Screen Display" the menu system and the service menu are the OSD.
Posted on Apr 21, 2008
No power
Posted on May 29, 2011
Aoc e2043 osd locked.How do I unlock? Lt button trick didn't work.
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. best regards
Aug 25, 2012 | AOC LM742 17" LCD Monitor
My monitor is eperiencing OSD locked and it keeps on popping out the screen. how do i fix it?
Hi rimandopaolo,
I see that you are getting the OSD locked pop up on your screen.
Press the Menu button on your LCD monitor look for the OSD option on the menu once pressed selct the OSD option try to see if it will give you an option to unlock the OSD setting on your LCD monitor
I hope this helps.
Have a nice day,
mvincentc
May 11, 2011 | Hannspree HW191D LCD Monitor
Aoctft 19w80ps osd lockedhow to reset
To unlock the OSD you need to hold the menu button for 20 seconds.
Hope this helps,
Chris
Mar 08, 2011 | AOC LM742 17" LCD Monitor
My monitor says the OSD is locked I can't unlock it
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD
Or else you can try this method also, Hold the menu/ok button for ten seconds, to unlock the OSD. If this doesn't solve the problem, then it's probably the button that got stuck. Remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers. Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
May 18, 2010 | LG 22" FLATRON LCD Monitor
Gateway FPD 1830 18.1 in. Flat Panel Problem
Usually in these cases the power supply would be the issue, but you say the OSD window shows up clearly, So the LCD panel is good and the Power Supply /inverter depending on which your FPD has.
FPD 1830 should have 3 boards(logic, Inverter, Power) otherwise just 2(logic, power)
If it is super dim, the problem is the inverter. Or the Power Supply if the inverter is embedded
Otherwise what your issue is the logic board, if you can swap out that part for a good one, Chances are for sure that you will have a spanking new FPD working.
I've worked with these a lot. Im working on one right now.
I hope this helps
Wish you luck
Victorsinferno45
Sep 11, 2008 | Gateway FPD 1830 18.1" Flat Panel LCD...
Problem in TFT
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jun 09, 2008 | LG L1915S 19" LCD Monitor
OSD lock
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds.
May 12, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
OSD lock
On LG monitors (like the Flatron series) you have to press on the menu button for about 5-6 seconds)
it's in the instruction book.
Apr 23, 2008 | Computers & Internet
OSD Lock
  • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Apr 18, 2008 | AOC LM729 17" LCD Monitor
Computers & Internet Logo
1,145 people viewed this question
David Payne
David Payne
