EW 1050 F My front loader washing machine is not emptying. It ends the cycle, but the orange door ligh is still on. When the light goes out (sfter turning Programs dial to 0) there is still heaps of water in there.
    Brigadier General:
  • 6,966 Answers
with the indulgence of the others...
there may be a clog or blockage along the drain pathway. Pls verify that there are no obstruction in the flexible hose, the drain filter and the drain catch. In some models, there may even be a valve controlling the drain.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 21, 2008
    Genius:
  • 1,226 Answers
please try unplug the washing to the wall outlet for a couple of a minutes and then plug it again. change also the wash cycle setting.
melnavz
    Sergeant:
  • 264 Answers
Have you checked the Drain Pump. It may be the cause for the same.
    Genius:
  • 1,142 Answers
Please do a power cycle
  • Maanita Chadha
    Maanita Chadha Apr 21, 2008
    All you need to do is unplug the power cord from the wall socket leave it turned off for atleal 1 hr then reconnect it back it should resolve the issue.
  • Maanita Chadha
    The drain pipe is clogged please check the drain pipe, after this you can check the inlet pipe for water too as the filter in the inlet water pipe can be clogged too.
    Please rate fixya
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution...
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Apr 27, 2010 | Zanussi FS1455W Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Have a Dometic WMD 1050 front load washing machine and can not open the door
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 26, 2009 | Washing Machines
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
Front loader washing machine
This is normal, the unit usually goes into a SD or slow down mode. To stop this press the start pause button and the door will unlock.
Sgt 48
Jun 04, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Door unlocks and won't spin or drain
it sounds like a clogged filter
Please remove the filter on the side of the machine or the front.
Make sure you have towels handy.
Clear the filter out. If your pump cant empty the machine out you will get these problems
Make sure waterline is not obstructed
Apr 15, 2008 | GE WSXH208A Front Load Washer
HE3 Front loader Controls Locked
Try 'end of cycle' pushed down till the light goes off. Or locate the button with diagram of 'lock', & push down till the light goes off.
Dec 24, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
