Question about Energizer Rechargable Battery with Charger
Lost the instruction sheet.How long do I carry out charge & what does the green Lt indicate
  • 283 Answers
Energizer® Rechargeable Batteries and Chargers: Frequently Asked Questions - http://tinyurl.com/2byon9c
Posted on Jul 21, 2010
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
I have an 86 dodge d100, 318. When the vehicle is running, I pull the lever for the headlights, and the fuseable link from the positive battery post to the alternato blows. I have a 40 amp fuse in the...
you have a dead short in head lt wiring. try un plugging one head lt at bulb at a time. if continues to blow fuse inspect wiring in cicuit for any bare wire too frame.
Dec 04, 2014 | Cars & Trucks
Diagnostic lights a green, b & c orange
Rear Lights Dell Computer Error Codes
Rear LEDS are labled A through D and can change from green to yellow. Some typical LED reading might be:
A - yellow, B - yellow, C - green, D - green <-- Indicates a problem with the RAM.
A - yellow, B - green, C - yellow, D - green <-- Indicates a problem with the video card.
Refer to the Dell website for your specific model, as these lights can vary from model to model.
see more from this site
Jan 16, 2014 | Dell Precision Workstation 670 PC Desktop
Lost owners manual and was testing fuses at the junction box. do you have any info. as to what each fuse controls. i lost my dash controls ex. speedometer oil guage . its 1999 jeep cherokee ltd
Here is the diagram you were looking for, hope this helps :)
Cavity Fuse Color Description F1 -- -- Spare F2 -- -- Spare F3 10 Amp Red Headlight high beam left F4 15 Amp Lt. Blue Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094) (Repair tip: WJ flasher repair)
F5 25 Amp Natural Radio amplifier F6 15 Amp Lt. Blue Park lamps F7 10 Amp Red Interior lights F8 15 Amp Lt. Blue Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks F9 20 Amp Yellow Power outlets F10 20 Amp Yellow Adjustable pedals (2002-2004 only) F11 10 Amp Red Rear window defrost indicator F12 10 Amp Red Auto shutdown relay / "Fuel" F13 -- -- Spare F14 10 Amp Red Headlight low, left F15 10 Amp Red Headlight low, right F16 10 Amp Red Headlight high, right F17 10 Amp Red Instrument cluster, diagnostic connector F18 30 Amp ? Trailer tow F19 10 Amp Red Anti-lock brakes F20 10 Amp Red Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense F21 10 Amp Red Ignition Run / Start - PDC (Power Distribution Center) F22 10 Amp Red Ignition Run / Start F23 15 Amp Lt. Blue Brake switch F24 15 Amp Lt. Blue Foglamps F25 20 Amp Yellow Accessory delay relay (sunroof) F26 15 Amp Lt. Blue Cigar F27 15 Amp Lt. Blue Rear fog (export) F28 10 Amp Red Body Control Module, Acc/Run F29 10 Amp Red Rear wiper switch. Washer motors F30 15 Amp Lt. Blue Radio F31 10 Amp Red Ignition Start F32 10 Amp Red Ignition Run / Start - Airbag F33 10 Amp Red Ignition Run / Only - Airbag C1 20 Amp Yellow Wiper (Circuit Breaker) C2 20 Amp Yellow Seats (Circuit Breaker) C3 -- -- Spare
May 16, 2011 | 1999 Jeep Cherokee 4WD
Lost instructions for TE109 appliance timex timer.\r\nCan you help? Thank You & Merry Christmas
    • Plug your Timex seven day timer into a standard electrical outlet. Allow the timer's rechargeable battery to charge for at least 10 minutes before attempting to program the appliance; the battery will serve as a backup power source to prevent your custom programmed settings from being lost in the event the timer is unplugged or the power goes out.
    • Press the depressed "RST" button on the timer with the tip of a ballpoint pen to reset the timer's internal memory.
  • To Set the time on your Timex timer. Press and hold the "Set" button for three seconds or until the day-of-week indicator begins to flash. Press the "->" or "<-" button repeatedly until the desired day appears on the digital display; press "Set." Use the "->" or "<-" buttons to set the hours when they begin to flash; press "Set" when the desired hour is shown. Use the same process to set the minutes, then press the "Set" button again to confirm the day and time settings.
    • To Program a start time for your seven day timer. Press the ">" button to access the appliance's programming mode; the program number will begin to flash. Use the "->" and "<-" buttons to highlight the desired program number, then press "Set." Highlight the desired day and press "Set" again. Program the hour for your timer; press "Set." Set the minute and press the "Set" button to confirm.
    • wait for the timer to go back to std mode (like 10 seconds)
To program a stop time for your timer. Press the "Set" button to cause the day-of-week indicator to flash. Highlight the desired day and press "Set" to confirm. Adjust the timer's hour with the "->" and <-" buttons; press "Set" when the desired hour is shown. Set the minute for your timer and press the "Set" button again. Press the "Time" button to exit the setting mode.
Dec 17, 2010 | Timex Hardware & Accessories
Quadra 7865xl won't start unless plugged into an outlet. Sometimes have to press the button many times to start. Charge the battery to full (all LEDs green), start & unplug cord, will run for over an...
It sounds like you have an intermittent connection. When an internal power connection is lost, it will cause the charge indicator to indicate discharged. Check your solder connections, particularly the solder connections that hold the batteries in place
Jun 07, 2017 | Norelco Quadra 6885 XL Electric Shaver
Yes, it feeds the paper right through and the printout is blank. It's not the toner.
The Presence and absence of the charge on фоторецепторе in analog device is conditioned that that light reflected from original, gets on photo drum and discharges (it), accordingly from light, white, not containing scenes area, is reflected more light, than from black, containing scene area. Accordingly drum runs down where is absent the scene. The Toner has opposite drum sign of the charge, accordingly toner is carried on that area drum, on which is present the charge (the opposite charges are attracted).
More simply, in analog device toner lies on charged area drum.
In цифровом device all on the contrary. The Drum is exhibited (get lighting) by ray of the lazer i.e. there, where shines the lazer, drum runs down. The Toner in digital device has such sign of the charge, as drum so he lies on discharged area drum.
Now we shall consider the main reasons of the origin of such sort to faults, as white sheet (the absence of the scene on copies) and black sheet (potting the sheet on the whole surfaces by toner).
White sheet
1. Absence of the voltage on коротроне (roller) of the carrying (also is identified lower)
2. Does Not revolve фоторецептор (фотобарабан)
3. Absence of the earth фоторецептора (фотобарабана)
4. Problems with high-tension power supply unit (HVPS) (brings about that that is specified in p.1)
5. Is absent voltage of the offset of the magnetic gross, check contact on magnetic gross (particularly often on HP LJ1010 - break spring-contact when leading-in)
6. Distance from magnetic gross before drum more prescribed - a toner is not carried
7. Is Not exhibited drum lazer does not shine, locked шторка lazer, physical obstacle for ray, problems with lazer or management him
If you themselves will not be able to come to apply to service. If you manage, ask to note my help in Fixya Thanks Good Luck!
Sep 28, 2009 | Canon imageCLASS MF6530 All-In-One...
Have brand new APC 900 UPS and when plugged in, both green & yellow indicator lights flash. Non-stop. Left unit plugged in for 18 hours (off) to charge battery as info sheet suggested, but lights still...
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
Sep 19, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Energizer Rechargable Battery with Charger Logo
552 people viewed this question
Top Energizer Electronics - Others Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you an Energizer Electronics - Other Expert? Answer questions, earn points and help others
