Question about Poulan Pro 22" Self Propelled High Wheel Mower
I have a Poulan Pro Lawnmower M# PR600Y22SHP and need to know what type of spark plug to buy for it.
  • 755 Answers
Where is the location of the sparkplug on a self propelled poulan pro lawnmower
look at the front of the engine for a fat wire with a rubber boot at the end the plug is behind the boot
Mar 31, 2012 | Garden
SPARK PLUG FOR POULAN LAWNMOWER #600Y22SHP AND WHAT KIND OF OIL TO BUY. wANT TO DO MAINTIANCE.
Take the old plug out and it will have numbers on the side. Simply match them up and you can cross-reference them on the package of any other plug that looks like it fits. But I'm guessing that mower has a Brigg's and Stratton engine and the plug will probably be a RJ19LM (Champion Number), which is what 99 percent of the engines I work on take (gapped at .030). Also, most mowers today run on straight 30 weight oil (not a multi-viscosity such as 10W30, Just 30 weight). Hope this helps you and good luck. P.S. Your owner's manual will tell you what you need to know and the engine sticker will tell you the oil.
Jun 27, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Put Lawnmower on its side and changed blade. Put
Most likely you have flooded the cylinder with oil. You can try this and see if it helps you out.
Remove the spark plug, clean and dry it with carb cleaner, let dry, spray carb cleaner in the spark plug hole and thoroughly flush it out. Let is sit this way for about 20 minutes. Reinstall your spark plug and see if it will start up for you. If it does you are done if not go to an auto parts store and buy some starter fluid. Spray the fluid with just short burst into the air cleaner. Try to start it. Repeat and it should stay running in a couple of tries.
Jun 15, 2010 | Poulan "Poulan" Push Mower
No spark
Replace the spark plug then try this:
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Your ignition is on the "Engine Assembly" detail (PP3816 Gas Saw Type 1) here:
http://www.ordertree.com/modelinfo/PWE/PP3816-Gas-Saw-Type-1/75.PP3816-Gas-Saw-Type-1.1.59.1.html
If not your saw you can find yours here:
Poulan.com
http://www.order tree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If I can be of more help please reply below. I hope this was helpful.
Lou
Jan 21, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Lawnmower wont start
Are you getting spark first of all. If you are getting spark do you have good gas? If you have good gas most likely your carb needs some attention maybe you had some old gas sitting in there and something inside is gummed up it might need cleaning.
Sep 19, 2009 | Poulan "Poulan" Push Mower
What type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Sep 05, 2009 | Poulan Garden
Poulan Pro 36cc won't start
Spark should jump at least 1/8 inch gap.You would need the correct coil for the application spaced at 10 to 12 thousands inch.
You might unplug shutoff wire and try,it might be shorted a lttle causing weak spark.
Feb 19, 2009 | Poulan Pro Chain Saw 46cc 20"
i have a 950 zx poulan pro lawn tractor. it will start but when i release the brake it cut off . i can start it up with out sitting in the seat.
Jun 14, 2008 | Dryers
Poulan Pro 22" Self Propelled High Wheel Mower Logo
350 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
