Question about ASUS A7V333 Motherboard
A7V333 Bios Rev. 1018 Beta 004 Onboard Audio setup not possible. The setup instructions on para. 4.4.3 it is stated; that under Onboard PCI Devices Control. This option is not visible for me. Therefore I am unable to have the choice to enable onboard PCI audio. Is there anyone who can suggest a solution
  • 906 Answers
Good day Sir, (suggestion only) If the audio driver does not work try to download audio codec.
Posted on Jul 24, 2010
How do I test the Sound card when the Control Panel sound states no audio device?
You should check in Device Manager to see if your audio driver is installed and working properly. If not, reload it. You could also check in the BIOS setup to see if the onboard audio has been disabled. There is also a possibility that the onboard audio has failed. You can order a sound board to install in the nachine to restore audio capability. Just disable the onboard audio in the BIOS, install the card and load the drivers supplied with the card. Hook your speaker to the jacks on the new card and you're back in action.
Dec 06, 2013 | HP Pavilion a705w PC Desktop
How to disable VGA in BIOS Setup
In the bios there should be a tab for onboard devices. Just scroll through the tabs until you find one called VGA. Cycle through the options and pick disable if the option is enable/disable only selections....or pick auto if the choices are either onboard or pci-x , pci, etc...
Jul 25, 2012 | Gateway E-4620d Desktop Cpu Dual Core...
Manyal
EP-8K3A
Introduction
KT333 with VT8233A AGPset/266MHz FSB/3 DIMM with DDR333/1 AGP-4X/6 PCI/USB1.1/ATA-133/6CH Audio/ATX
Specification
PROCESSOR:
The Socket A compatible AMD AthlonTM XP processor 1500+ to 2700+, 600MHz to 1.4GHz AMD AthlonTM and AMD DuronTM processor up to 1.3GHz
CHIPSET:
VIA KT333 AGPset (KT333+ VT8233A)
DRAM MODULE:
184pin DDR DIMM x 3 for PC2700 Memory
DRAM Size: 64MB to 3GB
EXPANSION SLOT:
PCI x 6!A4X AGP x 1
ONBOARD I/O:
Winbond W83697HF LPC I/O integrated with FDD, Parallel, Game, Serial and IrDA v1.0 and Power-On Controllers
ONBOARD PCI / IDE:
PCI Bus IDE Port with PIO / Ultra DMA-133 x 2 (Up to 4 Devices)
I/O CONNECTOR:
PS/2 Mouse and PS/2 style Keyboard
COM1, COM2, Printer, Audio-in/out, MIC & Game Port connectors
USB:
USB connector x 4 (2 for Opt.)
BIOS:
Award Plug & Play BIOS
Built-in AC97 Digital Audio (by Realtek ALC650):
Compliant with AC97 2.2 specification
6 channel slot selectable DAC output for multi-channel applications
Supports digital SPDIF Out Function
EXTENDED FUNCTION:
Supports Hardware Monitoring Function by W83697HF
Supports exclusive KBPO (KeyBoard Power On)
Supports CPU Vcore , Clock and Multiplier setting via BIOS
Supports Memory Voltage setting via BIOS
Supports STR (Suspend To RAM) power saving Function
Supports Wake-On-LAN Function
FORM FACTOR:
305mm x 245mm x 34mm ATX Size
OS Supported:
Windows 98SE/ME/2K/XP/Server2003
Jun 05, 2011 | EPoX EP-8K3A+ Motherboard
My audio not install.what can i do?
Hi thebigbumble,
I'm not sure why your audio is not installed, but you can download the driver to install it HERE. Make sure you put in your model and operating system, and they will get you the right stuff.
Good Luck,
Please don't forget to leave a rating
Thanks
Mark
Sep 16, 2009 | ASUS A7V333 Motherboard
In need of a pci/pnp 586 manual. anyone got?
BIOS INFORMATION :
BIOS MANUFACTURER : PHOENIX BIOS V.4.05 R 1.0 - (C) 1985/1995
BIOS ID : UNKNOWN
BIOS DATE : 11/23/95
BIOS ROM SIZE : UNKNOWN
CHIPSET : ALi M1511 REV.4
SUPER I/O CHIP : SMC 665GT REV.2 FOUND AT PORT 3FOH
CASE LABEL :
COMPUDYNE - PENTIUM PROCESSOR
P/N: 91.AA884.003
S/N: 1900001233
INSIDE THE CASE :
3 ISA SLOTS
3 PCI SLOTS
4 EDO MEMORY SLOTS
1 ALi CHISET - M1513 A1 - 9542 TS2 - AC7129SB
1 ALi CHISET - M1511 A1 - 9538 TS5 - B40958SB
2 ALi CHISET - M1512 A1 - 9537 TS2 - B40954SA
SOUND ONBOARD - CRYSTAL - CS4232 KQ EP - 33 PIN CN11 WAVE TABLE - 07 PIN CN12 AUDIO MIDI
PHOENIX MULTIKEY - PHOENIX 1987-1993 ER129
PHOENIX MB - 586 PCI PNP - PHOENIX TECNOLOGIES - A448416
INTEL PENTIUM PROCESSOR 133
NUMBERS IN WHITE INK ON THE BOARD TOP SURFACE :
95115-1
V50S MB
and
48.57001.011
MADE IN TAIWAN R.O.C.
Aug 29, 2009 | Intel Motherboard
I have asus mother board P5GZ-MX and the problem is i can't turn off the vga onboard on this motherboard....Please help me with the best solution...
Did you install the graphics card first, then try to install the drivers from the graphics card's CD? This
method is doomed to fail.
Why?
Because Windows 'sees' a new hardware device, and tries to match up one of it's generic drivers. There
wasn't any drivers installed from the CD, so Windows just found the next best thing.
The drivers CD should have been installed first, then the computer turned off, unplugged from power, and
the graphics card installed.
Now the monitor is installed to the graphics card, and you're on your way.
This bypasses the default setting of using the on-board VGA.
What to do now? Delete the software you have installed in your computer, and start over. (Start>Control
Panel>Add/Remove Programs>Graphics software>Remove)
Also you may want to see if an IRQ has been set for PCI VGA. (It's Plug n' Play or otherwise known as PnP)
Go into BIOS Setup, and set an IRQ for the PCI VGA (The term you'll see is -> Allocate IRQ to PCI VGA)
How?
Don't know if you've entered your BIOS Setup before. If so, disregard Number 1 below. (I'm not trying to insult your intelligence)
1.After you press the Power On button, the computer manufacturer logo screen will come up, (or instead
of a pre-built computer manufacturer name, it will be Asus. Computer manufacturer logo? Examples: Dell, Gateway, HP, and so on) Watch your monitor screen closely. As SOON as you see the logo splash screen,
start tapping the Delete key. Tap in 2 second intervals. You will now be in the BIOS Setup utility.
2.You're in the Main Menu. Look across at the headings. Second one over -> Advanced.
Press the Right Arrow key on your keyboard. Advanced will now be highlighted. Press the Enter key.
Now you're in the Advanced sub-menu.
3.See the ->Onboard Devices Configuration heading? 6th heading down. Use the Down Arrow key, and
highlight ->Onboard Devices Configuration Now press the Enter key.
4.See the ->Advanced PCI PnP Settings heading? Use the Down Arrow key to highlight it. Press the Enter
key. Now use the Down Arrow key and highlight -> Allocate IRQ to PCI VGA. Use the Right Arrow key to
highlight Yes, or No. Either Yes, or No, will be to the right. You want it to state Yes. Use the Minus key,
( - ), and Change Value. Change it to -> Yes
Now press the Enter key. Then press F10, and the y key. (It will look like a capital Y for clarity. You'll
be tempted to hold the shift key down, and press the y key. This = NO. Just press the y key. The y key is
for Yes. ->Yes you want to save changes)
Your computer will restart.
Jul 17, 2009 | ASUS P5GZ-MX Motherboard
No audio on Dell Dimension E310
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=150155 go to that web site and a download should start comming up if not select the hyper link that says stac 92xx c-major hd audio.................if this works for you plz send me a reciew
Feb 28, 2009 | Dell Dimension 4600 PC Desktop
Can on board graphics be turned off on QDI Advance 6T Motherboard
To do this you need to enter your bios setup, under onboard devices you will find the onboard graphics. Click disable on it & your pci card will be your graphics. Hope this helps & please remember to rate my answer. Thanks.
Dec 29, 2008 | QDI Group QDI Advance 6T Motherboard
Sound
i need soundmax for my orange pc
Mar 27, 2008 | HP Compaq d220M (829160054797) PC Desktop
ASUS A7V333 Motherboard Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
