Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
I m using transcend 640GB.when i connect it to system explorer is not notifying the device.but it is visible in device and printer section of device manager
  • 146 Answers
Probably a drive letter conflict
go to disk management, right click on the trancend drive and change drive letter, choose a letter further down , maybe T for trancend
Posted on Jul 16, 2010
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Sep 11, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
Usb removable disk is suddenly showing as local disk
Check that the safety switch is not on the USB. Some of them have a simple on off switch that gets turned off. I have made that mistake myself even knowing they are there. If there is not one of these switches I would try the device in another computer and see if it comes up the same way again.
Feb 04, 2014 | Transcend 640GB Transcend StoreJet 25D3...
My laptop cannot detect my transcend harddisc storejet 640gb
is it external hard disk, try changing usb ports means keep it in another usb port & also try changing cables u are using to connect hdd
Aug 06, 2013 | Transcend Computers & Internet
Trouble with Transcend 640Gb external harddrive; chkdsk does not work.
You will have to format it. Format it in NTFS mode since it is high capacity drive. I think you are trying to use it for the first time. This also occurs if you have problem in hard drive but it is rare. Let me know after formatting, it is working or not. I will help you further.
Increase Engine Horsepower
Jul 23, 2012 | Transcend Computers & Internet
I can't open my transcent, the data is lost. what will i do to open it?
try it opening from address bar or explore.
if it is due to a virus activity and you consider your data as important use software called virus effect remover.
if the data is not important just format your drive
Jun 26, 2011 | Transcend 640GB Transcend USB3.0 StoreJet...
Transfer rate is too slow 1 - 2 MBPS write speed read speed is ok in USB 2.0. I formatted the drive using storejet and then the wite speed moved up to 15 - 20 MBPS. after copying 2 folders it again dropped...
I got exactly the same problem with my Transcend Storejet 25M2 500GB hard disk. Formatting didn't helpw much and specifically the write speed is very slow, formatting improved the read speed though.
May 16, 2011 | Transcend 640GB Transcend StoreJet 25D3...
My transcend 500 Gb is not getting detected
First try multiple USB ports. Second try on a different machine.
If the device does not work on another machine it is a good possibility that the drive or enclosure is broken. If the other machine does recognize the device try rebooting your computer with the drive attach sometimes Windows handles USB drives better if they are connected at boot up as opposed to plugging them in after the machine is up and running. If this doesn't work you will need to right click 'My Computer' and click Manage. From the new window that pops up take a look at the Storage -> Disk Management section, under this section you may see your USB drive listed on the right panel. If there is an issue with the drive it should say here, this means the device is 'visible' to the machine but there is a problem accessing it.
Mar 12, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
One day i connected my Transcend storejet with Macbook laptop of my friend and when he clicked the drive,computer started to make backup.He stopped the backup process in between.After that when i connected...
This is because of the file system...Mac uses a different kind of file system, while windows uses a different one...
You need to format the hdd before using in windows machine...
because your HDD file system would have altered by MAC...
Now format the HDD from device manager and you will be able to see the HDD under windows explorer...
Feb 07, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have a 25M Storejet transcend hard disk 640GB. The transfer rate of the hard disk is very slow. Its about 700 KB/sec. What might be the problem?
The problem is that you have connected it to a "USB 1.1" port, which is much slower than connecting it to a "USB 2.0" port. If your desktop computer has a "USB 2.0" USB port, use it.
If not, buy an add-in PCI card to add "USB 2.0" ports to your computer.
Dec 13, 2010 | Transcend 640GB Transcend StoreJet 25D3...
I have TRANSCEND JETFLASH V10 (TS8GJFV10) 8GB USB, recently i have updated pc with win xp sp3 and it is not showing any flash derives when connected with PC..
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Mar 02, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
199 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
