Question about Durabrand DWT1905 TV
Digital channel strength is low
My tv has a blank screen that says digital channel strength is low. I thought the problem was the satellite, but this is the only tv in the house having a problem. Sometimes it works sometimes it doesn't and I can't find the manual for it. thanks
  • 15 Answers
SOURCE: Can't view my digital channels
Get an outdoor antenna. Digital signals very rarely reach indoor antennas unless you are within ten miles of the signal origin.
Posted on May 16, 2009
gopakumarg43
  • 74860 Answers
SOURCE: my tv says digital channel
Hello
If you are using this TV with Cable connection, the strength of cable signal is low. Contact the cable operator and ask him to put a signal booster at your premises. If you are using it with On Air transmissions receiving, include an antenna signal booster at the mast of your yagi antenna on roof. OK
Posted on Jul 05, 2011
SOURCE: My TV says
I just looked at a TV last night for this. I don't know what you've tried yet, but I was getting that message until I went into the menu and selected the automatic channel scan. I forget what it was actually called, but you'll find it. After that, 19 digital stations came in beautifully with a cheap set of rabbit ears. (The scan will also find analog channels, which you can delete later on.) Good Luck.
Posted on Jun 13, 2009
rsheehan
  • 69 Answers
SOURCE: ILO SDTV. Just started getting white message on a
digital is plaged with poor coverage areas
you may need a taller ant
Posted on Jun 28, 2009
  • 60 Answers
SOURCE: i'm trying to set the digital channels on my
If you are using a regular antenna to receive the signal, then you would need to either find a signal booster of some sort, or improve the antenna. There are many antennas out there for the digital era, most of them are set-top multi-/omni-directional ones, but they have their limitations. Unfortunately to get a better signal, typically an outdoor antenna is needed, or a large expansive one in the attic.
Posted on Nov 19, 2009
How do I keep it on Digital? When I try and turn the channel, it goes to Video 1. It says Digital channel signal strength is low.
How to fix digital TV reception problems - Simplify Digital
www.simplifydigital.co.uk > Guides
SimplifydigitalJul 11, 2014 - This handy guide will help you fix simple digital TV reception issues with Freeview, satellite and cable TV set top boxes. ... If you're suffering from poor digital TV signal, it may be possible to fix reception issues quickly, at home. ... We're here to run you through how to fix TV ...
Digital television transition in the United States - Wikipedia ...
Dec 26, 2015 | Televison & Video
I've a problem. When i switch on the tv. It says no signal. I've thought of turning the satellite but it keeps saying no signal and the signal quality stays at 4%. How to do? Configuration: technosat.
firstly the satellite dish antenna must be correctly aligned to satellite you want to receive.
technosat setup" initial setup" select the correct safelite ,once selected u should see signal strength /quality then tune the channels...auto works best, after this you can create your own favorite channel list
Nov 17, 2013 | Televison & Video
Insignia NS-30HTV 30 screen is black on all inputs, and says digital channel signal strength is low, can i fix this?
you need to get a digital aerial first .then you can sort out any other problems from there
Oct 03, 2012 | Insignia NS-30HTV 30" TV
Sanyo mod dp19241-no pic 'Digital channel signal strength is low' is on screen
Hello
As the set reports, the strength of the digital signal it gets may be weak. An other possibility is the fault with its digital tuner itself. Check the digital signas strength first. You can contact your cable provider, and ask them to check the signal strength at your premises's cable end. If it found satisfactory, there is no other way than replacing the digital tuner of your TV.
It is a skilled work, and should be done either by any expereinced serivce technician or by the authorised service center for Sanyo at your town. OK.
Oct 23, 2011 | Televison & Video
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
Green speckles on screen
This is called "Digital Blocking" and it is not your fault. The cable provider has to come out and check signal strength to your house. This is usually caused by wet connections/cables.
If you are a satellite or antenna user, readjust for signal strength. Your TV is just fine.
Jul 29, 2009 | Televison & Video
MENU PICTURE ON TV BUT NO CHANNELS
This is a problem with weak signal strength, You will need to find a better place to put your television so it can receive enough signal to operate correctly. If this does not solve the problem, you will need to check the satellite box for problems with receiving the signal from the satellite. You may need help from the satellite company to check the signal strength output and input levels to make sure its working properly. I hope this information helps you solve you problem with the loss of satellite signal in your television. Thank you for using FixYa and have a nice day!
Jun 18, 2009 | RCA DIRECTV Satellite Remote Control
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
No Analogue or digital channels!
Hello - I just posted something too. Not sure if its the same problem as yours. If you get a response from elsewhere, please let me know. I'll do the same. In our case we have a blank screen with a bar running across the top of the screen reading 'No signal' on left side and 'C611' on the right side. The 611 might be the last channel we were on !
Mar 07, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Durabrand DWT1905 TV Logo
1,047 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
