Question about KitchenAid KUDC25CH Dishwasher
KitchenAid Dishwasher Leaking
I have a KitchenAid dishwasher KUDC25CHBT1 that is leaking on the exterior of the unit from the water inlet opening. It only leaks while filling. Is this a replaceable part, and if so, how is it removed? The user guide diagram only shows the interior of the unit, not the part attached externally. Any help would be much appreciated!
  • KitchenAid Master
  • 43,501 Answers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
DishwasherKitchenAid Dishwasher Leaking - 2_bing.gif Trouble No Water entering Dishwasher2_bing.gif
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Jul 19, 2010
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
BOSCH SGS44E12EU/71 DISHWASHER LEAKING WATER INTO TUB
see this causes:
Main tub seal
if your machine is mounted horizontally the pump must be replace.
but if you have vertical machine follow this step:remove the lower rack+spray arms+spray arms support+wash /drain impeller see the diagram, then replace the seal.
Door gasket or seal
replace
Water-inlet valve
water inlet valve, leaking , replace.
Hoses
replace the clamps+hoses.
see the diagrams.
God bless you
Jul 11, 2012 | Dishwashers
Water leaking under the dishwasher
I have Kitchenaid model number (KUDE70FVSS2) and thought it was great (so quiet) until recently when I had to remove it for unrelated reason. That's when I noticed leaking (slow drip) when running. Laying on back (to prevent water going everywhere) isolated problem to the motor (diverter motor) and with a little internet research discovered that the factory had installed the washer (between the motor and the sump) upside down! Washer has deep groove which should face downward so that it covers part of the motor housing and seals completely. Well as result washer had been leaking (slowly) for a while, and on top of floor damage, motor connectors corroded into nothing. Motor actually seems fine and (be warned) replacing wouldn't fix the problem. Now trying to figure out how to reconnect wiring to motor without having to buy whole new wiring assembly. While motor replacement is fairly easy (two screws and two wire connectors), replacing entire wiring assembly involves door disassembly, lots of connectors and it's twice the price of the motor. Grrrr so mad at manufacturer now since this seems like intentional obsolesce.
efac4cf2-0542-4eb2-bb73-eadaf192d266.png e9aafc3a-da97-45ca-83e3-bd424971ad46.png 6deca94c-b9a9-4f73-89b3-da843200872c.png 4bcdf922-94a3-4853-bca5-e89d20798320.png
May 09, 2011 | KitchenAid KUDE70FVSS Builtin Dishwasher
I have a KitchenAid dishwasher KUDC25CHBT1 that is leaking from what I believe is the water inlet. It only leaks while filling. Is this a replaceable part, and if so, how is it removed?
Ok if it only leaks while filling, and not while running, it is probably the fill hose that goes from the fill valve to the washer. This hose can be accessed by removing the lower kick plate (2-4 screws) look on left side you'll see your incoming copper tubing (or hose) and a larger hose with clamps on each end It may have vibrated a hole in it or be leaking at clamp. Another possibility is the fill valve itself is cracked and leaking only when the valve is on.
Jul 16, 2010 | KitchenAid KUDC25CH Dishwasher
My KitchenAid Superba (whisper quiet ultima) started to leak out the front when it is running. Is this an easy repair or should we think of replacing the dishwasher? BTW - we love this dishwasher!
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Mar 18, 2010 | KitchenAid Dishwashers
The dishwasher leaks.
Check the following in the same order as i mentioned :-
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | KitchenAid 24 in. KUDG25SH Built-in...
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
Whirlpool Model DU840CWD
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
stustr
Dec 14, 2008 | Whirlpool 24 in. DU800CWD Built-in...
Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Nov 03, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Leaking Dishwasher Help!
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Dec 12, 2006 | KitchenAid 24 in. KUDI02FRSS Stainless...
Open Questions:
See all KitchenAid KUDC25CH Dishwasher Questions
KitchenAid KUDC25CH Dishwasher Logo
358 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
