Can i connet my cable network from my p.c to my new macbook
  • 2,351 Answers
If you have two Rj45's in your PC you can. Cable is connected to your cable modem. Than another cable called a Rj45 (Looks link a over sized telephone jack), connects from the modem to your PC. The simplest & cheepest way would be to buy a splitter for the Rj45 cable. (A lot less money than buying a second network card. Take a look at the link.(Click it once).
You will also need another Rj45 cable to go to your macbook.
And lastly, if you want to be able to sit any where in your home & still maintain an internet connection you can buy a wireless router. If your mac has a built in wireless network card.
This is pretty cheep compaired to other wireless routers around.
Have more questions, feel free to ask.
Posted on Apr 21, 2008
  • Mike Peluso
    Mike Peluso Apr 21, 2008
    How to vote you're expert & also how to repost more questions for same problem or answer expert's questions.
    Enter site.
    Sign in to your FixYa account.
    Locate My Profile on our FixYa's homepage.
    Under My Problem locate your problem and click on it.
    Under the solution given by the expert, choose.
Connect with ethernet adapter with mac
Connect the adapter the Macbook Air. Then follow this guide.
1: Turn off WIFI
2: Go to System Preferences
3: Network
4: your will see a box saying (New Interface Detected)
5: click OK
6: on the side block you will see USB/Thunderbolt Ethernet
7: click on it
8: from the option Click Using DHCP
9: You are Done
Hope this helps
Apr 10, 2014 | Kanex USB to Ethernet Adapter
Dear D-links, I have a DIR 300, I had installed
if you can connect to your router using a cat 5 cable with your macbook.
you need to reset your router if you do not know the password.
reset it by holding the reset button and power on the router while holding the button for 30 secs.
the default login/pass is admin/admin
follow the guide below here
to secure your wireless network.
Mar 20, 2011 | Linksys Wireless-G Broadband Router
How do i start withis laptop i can not connet to the internet
Check your network cables.
Also check your adapters by going to Start > Control Panel > Network Connection and make sure they are all enabled.
If you are using wifi, right-click the adapter in above location and click View available wireless networks and connect to your network.
Mar 15, 2011 | Computers & Internet
I have a macbook and a pc with a cable modem and an airport extreme. I want to hook them both up so I can use the internet at the same time on the pc and the macbook. How do I do this or hook it up?
Not sure what you have tried yet, so I'll suggest the first thing to try ...
The cable modem will have an ethernet jack on it for "LAN" - you will need an ethernet cable ... plug the cable into this jack .. and the other end of the cable into the airport extreme .. and then power up the airport extreme .. if the airport extreme is new, it will set itself up automatically .. if not new, it might still set itself up automatically - look for a green light on the extreme ... if you have a green light you should be in good shape
Of course your computers have to be in range, say within about 100 feet of the extreme to pick up its wireless signal.
In the MacBook, make sure Airport is turned on - in System Preferences under Network.
Your MacBook should figure things out all by itself and you should be able to connect to the Internet.
On the PC, you'll need a wireless card if you don't already have one ...
You should be able to use the internet simultaneously and each computer should be able to share files if you want to try that (file sharing is turned off by default on the Mac, not sure about the PC)
For AA speaker tapes and PA system help with feedback and echo, see my blog at
Dec 19, 2009 | Apple AirPort Extreme Router
New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Jan 05, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Faillure connection
I think in cable is faulty, when conneting to pc to switch, cables as to straight cables, pls cross check the cable..
Jun 03, 2008 | Computers & Internet
I restored my modem and I lost my verizon connection
Ok there are few steps to solve the problem
  1. goto My network places and make the connection
  2. double click the make new connections and select which country and enter zip code of your country. and select tone or pluse.
  3. enter the new connetions.
  4. After finish that the window comes like welcome to network connections wizard.
  5. choose which connetions you are using like dial up or boardband connetion which high speed
  6. follow the wizards and select the region and connetions of which type internet and zip code.
These are modem connetions of intial part of the connecting the internet.please inform me any other .
Apr 30, 2008 | Computers & Internet
GCC 12/600 Not found under Leopard (on wireless network)
Same problem.
Plus I am trying to find a legitimate download for a 12/600 printer driver that will let me print from my new MacBook Pro running Jaguar.
Peter B.
Jan 07, 2008 | GCC Technologies Elite 12/600 Laser...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
