The lid switch is stuck...how do I get to it to replace or repair it?
  • Washing Mach... Master
  • 8,220 Answers
That orange wire is a ripcord. Remove the pamel reach up and grab that orange fishing line and it opens the door manually on a maytag washerThe lid switch is stuck...how do I get to it to - 9ee2679.jpg
Posted on Jul 16, 2010
Our Kenmore top load washer does not want to pump out the water. Model # seems to be 110 925 73210, set no. CE 1320006. After filling and agitating it won't drain. There is no pump noise.
The most common cause of the symptoms you describe is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid strike (if equipped) usually costs less than $5. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If model number is correct, the part number for a replacement lid switch is 285671. The lid strike (actuator) is 350733. If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Oct 14, 2010 | Kenmore Washing Machines
My washer stops just before the rinse cycle sometimes the dial makes noise sometimes not
The most common cause of the problem you just described is a lid switch malfunction or lid actuator problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
repairclinic.com
If the model number is correct, the part number for a replacement switch is 8318084. The actuator to the switch will be a rod on the left hinge of the lid.
The average price of a replacement lid switch for this model washer is about $15 - $20 if you perform the repair yourself. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
Jul 13, 2010 | Estate ETW4100SQ Top Load Washer
Fails to start, but when you bang lid down, program begins
check the switch on the lid That may be faulty and need replacing
Please rate my help++++Thanks for using FIXYA
Jun 07, 2010 | Whirlpool LSN1000LW Top Load Washer
Will not start wash cycle until I bang the lid to engage the switch. Where is switch located to repair?
The lid switch is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
May 27, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Completes wash cycle, then stops at rinse with water still in drum
The most common cause of the problem you are experiencing is a lid switch malfunction. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number is correct, the part number for a replacement switch is 3949247.
IMPORTANT: It is strongly recommended that you replace the lid switch if defective. However, if you need to use the washer in the interim while awaiting parts, you can by-pass the switch by following these steps:
1. UNPLUG washer.
2. Unplug the lid switch connector from the timer and remove switch.
3. Cut the white plug off the end of the old lid switch, leaving about two inches of wire on the plug.
4. Cut the ground wire (usually green in color) flush.
5. Take the remaining two wires and splice them together.
6. Take this plug and plug it back in to the timer.
You have now by-passed the lid switch. Caution needs to be exercised when operating the washer without a lid switch. Make sure you turn the timer off before opening the lid to stop the washer.
NOTE: Keep this by-pass plug in your toolbox for future reference if you ever experience lid switch problems again.
May 20, 2010 | Whirlpool LXR6432JQ Top Load Washer
Will not drain or continue to rinse/spin cycle
The most common cause of the problem you are experiencing is a lid switch malfunction. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
repairclinic.com
1. UNPLUG washer.
You have now by-passed the lid switch. Caution needs to exercised when operating the washer without a lid switch. Make sure you turn the timer off before open the lid to stop the washer. NOTE: You will render the existing lid switch inoperable by making the by-pass plug. Keep the plug for future reference and replace the switch.
If you have questions, or need additional assistance, please post back with your MODEL NUMBER and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
May 15, 2010 | Kenmore 23012 Top Load Washer
My whirlpool washing machine is getting stuck in the wash cylcle right before it is to drain
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills, then stops and will NOT drain, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and there will be no small hole on the right hand side of the wash tub. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop around for the best deal.
This is a very simple repair, but if you have questions, please post back with a complete model number (usually located around the wash tub rim under the lid) so that I may be able to provide you with better assistance. I hope this helps you.
NOTE: You do not need to drain the washer to replace the switch.
Nov 17, 2009 | Washing Machines
Wash cycle stopped and won't drain or spin
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses and pump check out Ok, this will confirm that there is a serious fault within the actual control sector(Timer module). It should be replaced in this case.
Sep 28, 2009 | Kenmore 24032\24036 Top Load Washer
After the washer fills with water it stops and won't do anything
You have a bad lid switch. This can be a simple "do it yourself" repair....or at least an inexpensive repair if you call in a professional.
Jun 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine Model #110.91551200
The symptoms you are describing are a caused by a lid switch malfunction. A lid switch is a very simple and inexpensive fix. The following link explains how to replace a lid switch:
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms.
If the model number you have this listed under is correct, you can find replacement parts at searspartsdirect.com. Just type in the the model number and you can locate what you need under the "Top and Cabinet" heading. The lid switch is item number 11 (part #285671) and the lid strike is item number 20 (part #350733).
I hope you find this information helpful. The total cost of your repair is less than $50 if you follow the instructions in the link I provided and repair it yourself. Let me know if you require additional assistance.
Sep 13, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
