Back to:
Tags:
Receivers
Generic problem for all Receivers
P-200 piano some keys are
posted by marklyster on Apr 21, 2008
p-200 piano some keys are louder than others
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 21, 2008
Not Rated (0)
robotek
Rank:Guru Guru
Rating: 90%, 568 votes
Hi there marklyster
The keys are all touch sensitive. Generally speaking, there is not alot to go wrong in this area. They key contacts may be dirty creating the problem you have.
The keys are not as heavily weighted in the treble cleft on this model, could this be causing the problem. If it is certain keys that are affected, then I would suspect a contact problem. You may need to have the keyboard serviced.
regards
Graeme
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on p-200 piano some keys are:
I don't want to Accept this solution
Can you Help with these Receivers problems?
Receivers
I need a code for a radio in my 1999 nissan...
Yamaha RX-V661 7.1 Channels
Perdi o controle remoto e o manual do usu?¡rio do meu...
Receivers
kvt-815 forgot security code for radio operation could you...
Receivers
Yes i have a Memphis belle 1500 class D amp..I just hooked...
Receivers
turntable platter speed too low
Loading problems.
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
