Question about Radio Communications
Power cable for uniden pc 68 ltw
Hello i need a sorce perhaps locally for the power cable that plugs in back of this certain cb radio
    Sergeant:
  • 250 Answers
Hello NARCNSA,
I'm not sure where you are located, but this accessory is available directly from the manufacturer on the Uniden Direct webstie at:
http://www.unidendirect.com/accdetail.cfm?item=BWZY0517001
Best Regards,
Ken
Go Ahead. Use Us.
Posted on Apr 22, 2008
Fuse for uniden pc78 ltw
2amp to max of 5amp.. anything bigger will not protect the radio.if anything happens.
Feb 12, 2014 | Uniden Bearcat PC 78 XL CB Radio
How to add talkback to a uniden pro510xl
68 to 200 ohm resistor to the postive side of the speaker to board ground
Jan 28, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden pc-68 ltw stuck in weather band.
there is a capacitor ,I think its c801 that you have to cut .cb should be restored.unless you want wx.
Aug 19, 2012 | Radio Communications
Have a uniden pc 68 elite it seems everything works the whene transmitting the needle moves a. but it has no volume it makes no noise i have tried a different mic i have put a new ext speaker on it and it...
Could be audio chip.
  • Insert external speak jack into pa port.
  • Turn volume down
  • Switch cb/pa switch to pa
  • speak into mic
if you are getting audio from speaker ......chip is fine.
Jan 04, 2011 | Uniden Bearcat Pro PC68Elite 40-Channels...
Need service diagram
The service manual is the same for the Cobra 25 LTD. Both have the same boards and specs.
Glad to help out,
J.R.
Dec 26, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Old uniden cb radio. i have plugged it in and i know i'm getting power through the cigarette lighter, but no power when i turn on the radio. no lights, no sound, nothing. please help. any ideas?
Hello there
There is a internal fuse on the inside of the unit that might need to be replaced and also check the fuse that is in the power cord ok?
best regards michel
Sep 14, 2009 | Uniden Radio Communications
Modification of frequency output of uniden pro 510xl
deweyp, hi, if you are wanting to turn the power up some on the radio, do this; tune L4, L5, L6, L9 for
maximum RF forward output. There are 2 versions of the radio, and both are listed as 510xl. If you are wanting to expand the freq's or add channels, then no, there is no mod for that radio. If your going to tune the radio for more power, make sure you have a power meter to watch the output. It is preferable to tune into a dummy load so your not broadcasting over the air. You tune the radio for peak output, using a steady awwww sound in to the mic. Just be careful as that radio has a fairly small driver and final transistor. Don't want to let the factory smoke out of it,,,
Here is what the little variable adjustments are for and what they control;
VR1 Squelch
VR2 TX Meter
VR3 RX Meter
VR4 RX IF Gain
Hope this helps you out, let us know,, Mechanic
Feb 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Matching Antenna, or ??????
If the antenna is tunable, you definitely need to start out by having the swr set properly on the antenna. Also, make sure the plastic ferrel, (the small round white piece) is between the top of the antenna bracked and the antenna itself. It is there to make sure the antenna does not ground out to the vehicle. If the antenna is grounding out, it will be like no antenna at all. I have also had a few customers that have had broken coaxes straight out of the factory package on cheaper antenna setups.
Dean
Rollin CBs
Feb 08, 2007 | Uniden Bearcat Pro PC78LTW 40-Channels...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
