Question about LG DLG2532 Gas Dryer
On 1/20/09 had to replace Blower Wheel (cost$243.80 by AFCO Home Appliance -in Lynbrook NY.). And on 2/13/07 had to replace Motor Part No.468IEL1002A.....And now, machine makes again terrible rumbling noise as if drum touching something.....but am suspicious, that it might be again the Motor or the Blower....??? By the way, when Blower was replaced, the repairman left and when we tried it out, it did not sound right already then...and we should actually have called him right back, but my daughter did not....and today we have this problem again. My recommendation is to NEVER buy another LG Dryer again....what is your opinion and advise ? Thanks very much, Oscar Bosshart
  • LG Master
  • 3,361 Answers
My opinion is to buy Whirlpool.
Posted on Jul 16, 2010
Name of post master for lynbrook post office lynbrook ny
Pete Daniels Postmaster
Carol A. Koch Officer-In-Charge
Angela La Bianca Officer-In-Charge
Information may be outdated on postmaster.
Aug 03, 2017 | Computers & Internet
I have a Preway gas wall oven. Repair man said it was 55 years old. Guessing he couldn't know the exact age so late 50's/early 60's. It remains lit until about 3 or 4 minutes of preheating. Then the flame...
Try contacting them directly- I bet they might be able to help. Please don't take this into your own hands and attempt to rig something up, unless you're a professional. Especially when you're smelling gas during pre-heat. Here's their contact info:
Preway Service Inc.
Appliance Repair Service
27 Rocklyn Ave.
Lynbrook, NY 11563
(516) 593-1316
Aug 26, 2014 | Ovens
Blowing fuses on blower motor 2006 e250 econoline
Both are possible.But it can be blower motor issue mostly.Its taking too load and that's blowing the fuse.How to Test and Replace Blower motor on car? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-and-replace-blower-motor-on.html--------- How to Replace Blower Motor Wheel? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-blower-motor-wheel.html
Also more help solutions recommended. Click the link below :---
Blower motor replacing for all vehicles? http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
----------Blower motor Resistor shorting problem? http://schematicsdiagram.blogspot.com/2011/12/blower-motor-resistor-shorting-problem.html
--------This will help.Thanks.
Jan 25, 2012 | 2006 Ford E-250
I have a maytag heavy duty gas dryer model number LDG412 i need to know how to clean the vent all the way to the duct, the dryer is getting hot but it is taking a long time to dry clothes now, inside where...
while cleaning the venting is never a bad idea and i recommend its done yearly,a common problem with older (the ldg 412 is from the mid 1980's) Maytag dryers isa stripped drive hub on the blower wheel and absolutly no air is being circulated throughout the dryer. A lot of times when starting the dryer and when it stops a rumbling noise will be made if the blower wheel is the problem. To check it if is the blower wheel you can remove the front panel by removing the screws that are a slight angle at the bottom of the front panel,tilt it out toward you at about a 45degree angle,then off. At that point remove the four 5/16" hexhead screws holding on the front drum support,lift it up slighly then off. The blower wheel will be in the lower left corner and you could spin it by your hand if it spins around the motor shaft it slips onto and does not move the drum while turning the blower wheel,it is stripped and needs to be replaced.To replace it remove the 1/4" hex head screws that hold the front plate to the plastic blower housing(7 screws) and the 5/16" hex head in the tab also in the plate in the front of blower housing the plate where come off. To replace blower wheel remove the greenish/black clamp from the center hub and the thin metal ring that fits ina groove on the motor shaft, a special c/e clip ring pliers are needs to remove the ring. A inexpensive pair could be picked up at most places that sell tools(ace hardware/lowes/home depot/sears) The part number for the blower wheel is 303836 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
assuredparts.com
I hope this will help you to repair your dryer,
Gene
Aug 07, 2011 | Dryers
My dryer runs and heats but seems like no air is being blown. It should have some sort of a blower correct? Taking 2 cycles to get dry and vent is not clogged, but not sure about lint trap slot.
First, of course, make sure ALL the airways are clear, including the area around the lint filter, and the outside vent - lint likes to stick to the outside vent flap, so make sure you clean that off too, and that it opens and closes freely.
Here's how to get the dryer apart
http://fixitnow.com/wp/2004/03/22/appliance-tip-of-the-day-encore-dryer-disassembly/
There is a blower wheel, but it's powered by the same motor and belt which turns the drum. So if your drum is turning, the blower wheel should be turning, too. If not, you may have to replace the blower wheel. Here a link showing how to do so:
http://fixitnow.com/wp/2010/06/30/replacing-the-blower-wheel-in-a-whirlpool-built-dryer-with-the-lint-filter-in-the-door/
Mar 26, 2011 | Kenmore Dryers
How to replace a blower motor in a 1996 ford thunderbird lx
Removal
  1. Remove the glove compartment liner to gain access to the heater blower motor and blower motor wheel assembly mounting screws.
  1. Use a small screwdriver to remove clip retaining hydraulic damper strut.
  1. Remove four screws and remove the heater blower motor assembly and blower motor wheel assembly from the heater blower motor housing.
Installation
  1. Using a new seal, position the heater blower motor and blower motor wheel assembly to the heater blower motor housing with the flat side of the flange near the heater blower motor switch resistor (18591). Install the four retaining screws.
  1. Tape the heater blower motor power lead to the air inlet duct to keep the wire away from the blower outlet during installation.
  1. Install the heater blower motor and blower motor wheel assembly in the vehicle.
  1. Install the glove compartment liner.
Oct 07, 2010 | 1996 Ford Thunderbird LX
How do I replace the ac/heater blower moter?
Hope this helps....please don't forget to rate...thank you:
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  3. Disengage the wire harness connectors from the retainer.
  4. Disconnect the blower motor electrical connector.
  5. Remove the motor cooling hose.
  6. Remove the screws and remove the blower motor.
    NOTE
    Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
  7. Remove the wheel from the blower motor as follows:
    • Remove the push clip.
    • Remove the wheel from the blower motor.
Blower motor cooling hose
Blower motor mounting plate
To install:
  1. Install or connect the following:
    • Wheel to the blower motor, if removed.
    • Blower motor and securely tighten the screws.
    • Motor cooling hose
    • Blower motor electrical connector
    • Wire harness retainers
Sep 15, 2010 | 2005 Mercury Grand Marquis
Ford windstar98 heater problem
its either 1 of 2 things. either your heater control is a lil faulty or the blower motor is going..up here in southern tier ny at napa the switch lists at $13 the blower motor now for the parts under the hood. main unit lists for around $42 the rear unit without the blower wheel lists around $43 and the whole thing assembled runs for about $120
(those prices are rounding UP to the next dollar i cannot verify if the prices are the same around your area. but NAPA can :-D )
Oct 18, 2009 | 1998 Ford Windstar
My coleman 3 ton heat pump blows very little air
Check the blower capacitor and blower speed, you probably have a 3 or 4 speed motor make sure it's on medium high or high speed.
If these are ok then shut the power off to the indoor unit and pull the blower housing out so you can see the blower wheel, make sure it's clean and very carefully spin the wheel to see if it spins freely keep hands away from wheel while it's spinning, if it doesn't then the bearings are bad and you need to replace the motor.
Apr 28, 2009 | Heating & Cooling
Replace blower motor in Lennox gas heater
It is a fairly simple operation. The hardest part may be seperating the blower wheel from the motor shaft. I recommend first sanding then applying a little oil to the old shaft. Prop the blower housing aprox. a foot off the floor with the motor facing down then using a wrench (NOT pliers as you may scar the shaft) hold the wheel with one hand and work the wrench on the shaft work it back and forth to loosen. DO NOT hammer on the end of the shaft as you will mushroom it ever so slightly. The weight of the motor should cause the shaft to slide down. Good luck and don't forget to answer back if this works or not.
Jan 18, 2009 | Heating & Cooling
LG DLG2532 Gas Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
