My usb ports just stopt working 4 no reason - Computers & Internet
  • 86 Answers
Try to install new Operaing system and then check again.
Posted on Jul 16, 2010
Trying to connect hdmi cable to laptop to watch movies
Are you sure you have four hdmi ports? I have only one hdmi port and three usb ports. Be sure you are connected to the hdmi port and for some reason not a usb port.
Aug 17, 2012 | Sanyo DP46849 46 in. HDTV
All of the sudden it stopt working. Nothing happens when I push the ON button. I changed batteries. I took the backup battery out and put it back in (didn't put new one). Nothing helps. I changed the...
It is sold with an dapator that powers the calculator through the USB port. Use it and you will eliminate any doubt about the batteries. Try resetting the calculator.
Aug 26, 2011 | HP 50g Graphic Calculator
Not working USB data travelter 4 GB message error is USB device not recognized plz solved this problem and send me best clarification.
Hello and Welcome to FixYa!
The error you quoted can be due to multiple reasons. Following are some main Possibilities, that you should keep in mind.
Make sure, the USB port, you are inserting data traveler in, is in working condition. And you are connecting the device properly.
This could happen due to Software conflict, for this you need to remove all the devices connected to USB ports (other than keyboard, and Mouse) and need to restart the system.. Moreover, you can check for the exact error, in the device manager list...
Try checking the data traveler, on some USB port, on which you are sure, that its working properly.
Check for the possibilities, quoted above and do let me know....
Concerned.
Jun 25, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB port stopt working. Got an error in device manager. Unknow device under usb controllers. There is no driver installed. Reinstall all the drivers, then i get the message all drivers are already...
the easiest way to fix this problem is using a linux free live distro to boot up your pc and check if the USB works. If it doesn't, it means your motherboard has some broken transistors/components and you may need to change it if still under warranty. To boot up from a linux cd, you need to download an iso (from here http://www.livecdlist.com/) and burn it on a cd. Then you must restart your computer with the cd inserted and boot from it (you can consult your motherboard's manual for the how-to).
Hope it was helpful,
Franz
Mar 01, 2011 | Asrock G31M-S Motherboard
USB ports appear to not be working. Any clues?
Go to setup turn on the USB 1.1
The USB port is turned off for security reasons;
You may consider adding a 4 port USB 2.0 adaptor card my server has Both I use the onboard USB 1.1 for external hard drive and mouse
Nov 19, 2009 | Dell PowerEdge 4600 Server
4 port USB hub not working...
Try connecting the hub to another USB port. You may even connect this same device to another computer and check if that works. This will help isolate the issue better.
Jun 23, 2009 | Dynex 4-Port USB 2.0 Hub
Usage of KVM 2-Port USB between 'thin client' and 'Desktop' stopt
KVM are not the most reliable and will fail sometimes. The quickest way to get it back is to plug into a different USB port for the one that is active.
Jun 22, 2009 | Belkin F1DK102P 2-port KVM Switch
1 USB Port Failure
Hi Guys
Unfortunately after looking at the computer installation details i was at fault, although i have had
the computer for well over 2 years and this is the first time it has happened.
My Dell Dimension 5150 has 7 USB ports 5 at the back and 2 in the front and it appears that i have
connected the keyboard and mouse to the wrong ports.
There are two ports at the bottom allocated for the keyboard and mouse and for some reason i had
them in the top three ports hence my problem but still not sure why it happened.
Anyway my Dell Dimension 5150 is now running OK and no further help is needed.
Many Thanks.
Nov 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Jun 01, 2007 | Intel Motherboard
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
