Question about Hitachi 65F59 65" HDTV
My screen intermittently flashes green. On occasion it goes negative (or thermal) or becomes completely distorted or goes green. I usually have to shut off the tv then turn it on and all is good. Now the picture is flashing a green tint and it will not stop. I shut off the cable so the tv is black and you can see it is still happening so it is definitely the tv. Any ideas?
hardrocko
  • 1476 Answers
SOURCE: power and picture
Sounds like you have some bad solder joints. The problem is not fixing them but finding them. If you can solder and know TV safety you should be able to repair this. Unplug the unit and remove the back. The bad solder joints could be anywhere. Remove each board and look at it with magnification to identify the bad joints and resolder anything which looks suspicious. You could also resolder all the connections on the power supply board and see if that solves your problem. From your description of the problem it sounds like that is where the problem is located. Good luck.
Posted on Jul 19, 2006
MikeNJ1964
  • 398 Answers
SOURCE: picture distorts randomly and resolves by turning off and back on
I do wish sgregg would stop giving advice on things he obviously knows nothing about. The 65XWX20B is a standard projection set and does not have a lamp in it. It has 3 separate picture tubes. The power board is not the problem either because you would get no picture if it failed. You most likely have a convergence IC which is on the verge of failing and is starting out OK but acting up when it starts heating up inside. A good tech will replace both STK392-110 IC's with the newer updated STK392-150's, realign the convergence circuits and be done in about an hour and a half. When I do a housecall for a set like that I charge $150, but techs in your area will vary so ask around.
Posted on Aug 10, 2007
ctf1800
  • 4402 Answers
SOURCE: flashing green on screen
did he spay something in ? or more like a vacuumed or didn't see?
Posted on Dec 05, 2007
ctf1800
  • 4402 Answers
SOURCE: Red Light
convergance ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 14, 2007
  • 27 Answers
SOURCE: green picture and distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Posted on Jun 14, 2010
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
I Bought Toshiba LCD TV Model 32A3000E 3 years ago, now when we switch on for approx 2hours the LCD screen distorted with green and red colour and getting worse. The next day it is ok again and here goes...
If the tv tend to operate when it gets warm this cause a thermal intermittent problem, common cause is the cold solder or loosed connection try to check the main pcb or the power supply solder side of the board then try to observe if there is cold solder or slight cracked to the lead try to solder that part. Note before opening or removing the back cover of your tv, be sure to unplug it first to avoid serious injury. Or try contact a service repairman to do it for you to lessen the stress. good day hope this may help.
Jul 13, 2011 | Toshiba Televison & Video
NAD 7020e sudden volume drops, sudden distortion- intemittently
OK. I dont know the answer to your prob, but to let you konw that youre not in this alone, my amp used to occasionly lose considerable volume in one channel. this could be remedied by cracking the volume up to max for a half second or so. (Not a great solution!!) It has finally given up the ghost ...I have lost one channel and the doctor says it wont come back. Not only this but they claim that spares ceased to be sold back in the 90's. having said this I have enjoyed this amp for almost 20 years. I think its time to put it to pasture.
SNO
Apr 12, 2010 | NAD Audio Players & Recorders
After turning of the TV for a few minutes, it won't turn ON. The power LED turns green for a second and then becomes red and flashes, Philips Model 32PF7321D/37
grodmx74, You or electronics technician will need to find the "thermally-intermittant-hair-line-fracture" of a component soldered to the switch-mode-power-supply printed circuit board with aid of large magnifing glass or use a 10x or 20x inspection microscope, and then resolder the connection. 12fixlouie
Apr 02, 2010 | Philips 32PF7321D 32 in. LCD Television
When i turn the mp3 player on, it goes directly to the language screen. when i enter the music screen and select tab, the screen becomes distorted, nothing works
  • Try resetting the device it’s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
  • Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer’s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Dec 06, 2009 | SanDisk Sansa e260 MP3 Player
Samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
Jul 02, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Convergence with green color.
Your symptoms sound like an intermittent connection on the convergence IC’s.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
There are two ways to repair intermittent connections on the convergence IC’s. I usually remove the board with the convergence IC’s on them and then and solder the connections. The other method is to tilt the circuit board and solder them while still installed in the chassis.
If you remove the board and repair the connections, be careful to remember which connections need to be made when you replace the board. Mitsubishi uses a lettering system, so it should be easy.
If the problem remains after you have made the repair, it is possible that the pins on the IC’s have become loose. In this case the IC’s need to be replaced. I have seen this on several occasions.
If you choose to repair the set yourself, be very careful of the high voltage that can be stored in the capacitors, and CRT’s. This voltage can be as high as 30,000 volts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 21, 2009 | Apex Digital GB55HD09W 55" Rear Projection...
Diagonal green lines on a green screen
It is possible that the electron-gun inside of the CRT is having an intermittant short. It is also possible that there is an intermitttant failure in the bias or drive circuits for the CRT electron-gun.
The TV service tech would have to run some tests to determine the actual fault, and then the failed components.
If the CRT is at fault, the set will not be worth to service.
Jerry G.
Apr 25, 2008 | Televison & Video
Acer 5610z screen
There are a number of possible problems.
When the computer is turned on and you wiggle the LCD back and forth and the video becomes corrupted and then if you wiggle it some more and get it to work correclty then you either have a loose video cable connection or a defective video cable. In some cases the LCD will need to be replaced.
If this is not the case then there is the possibility that the video card is bad.
Dec 30, 2007 | Acer Aspire 5610-4648 Notebook
Screen goes black, 5 blinking red lights, screen back on for 20 seconds....cycle continues
Let me first say that if you are getting 5 blinks its not the thermal fuse. Your problem is your Lamp. You have what we call an intermittent Lamp. The only way to fix this is to replace the lamp. Part Number A-1085-337-A. Average cost $217.00
Circuitcity
Dec 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
Hitachi 65F59 65" HDTV Logo
43 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
