Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
Have gas in oil - will not start
Have a Model # 917.28870 Professional Craftsman Mower - 24hp with 42" deck. Complete service at 50 hours - changed plugs also.
At 65 hours the mower started sputtering and needed choke to stay running. Within minutes quit. Investigating I found gas in oil.
What is the most likely problem?
Thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Gas in oil is usually a symptom of flooding, caused by a stuck needle valve or damaged float in the carburetor. But 65 hours is awfully "young" for this problem.
Posted on Jul 17, 2010
How to check mower deck bearings on a craftsman 24hp with 42" cute
grab blades with glove on and pull sideways back and forth if you fill them move they are bad replace them
Sep 08, 2014 | Garden
What would cause a craftsman mower not to have enough power to start #917272672
Low compression most likely. Try changing the spark plug and change the oil. Sometimes the mower won't start if the oil level is too low. If that doesn't correct the problem, then you need to either rebuild the engine or replace it.
May 19, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 50" 24hp , model # 917273220
You can eliminate the seat swith by unplugging it and putting a paperclip in to make a jumper and trying it.
Aug 07, 2012 | Craftsman Garden
I changed the oil in my Craftsman Lawn Tractor 24HP Model No 917-288320 and the "change oil" message on the LED screen won't go away. Is there a reset button somewhere?
Below is excerpt from the owners manual:
SERVICE REMINDER/HOUR METER
Service reminder shows the total number
of hours the engine has run and flashes to
indicate that the engine or mower needs
servicing. When service is required, the
service reminder will flash for two hours.
To service engine and mower, see the
Maintenance section of this manual.
NOTE: Service reminder runs when the ignition
key is in any position but "STOP". For
accurate reading, be sure key remains in the
"STOP" position when engine is not running.
It should reset the 2 hours has expired
Jan 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Smoking Craftsman Riding Mower
1st thing, check your dipstick up inside the cap part of it and make sure the O'ring is there and in good condition.
2nd, make certain when you put it back on that you get it on straight and firmly seated. They will only seat one way properly the other way creates a leak into the crankcase and causes oil consumption and smoking. You should be able to tell if it has been improperly installed by an excessive amount of oily dirt accumulated around the threaded area of the cap
Sep 15, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman II mowre oil capacity and filter type
The outstanding Briggs opposed twin engines have an oil capacity of 1.5 qts. The recommended oil is 10w30 full synthetic and 50 hour change intervals. Some engines were equipped with an oil filter, if so, the capacity is 1.7 qts. fantastic engines, take care of it.
Mar 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
248 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
