Question about Sram 3.0 Comp Twister Front Mountain Bike Shifter - 00.0000.200.657
When i change gear on the front cogs it doesn,t stay on unless i hold the gear shift
    Brigadier General:
  • 8,546 Answers
Rear double click SRAM shifting does not work at all hardly. It's supposed to be a smooth transition up/down with single/double click pushes. I can't seem to get it to change it from the two...
The only thing that allows the derailleur to shift to smaller cogs is the spring in the derailleur pulling the cable through all the housing. Therefore if your shifting is stubborn there is too much friction for the spring to overcome. Can be multiple reasons - rust/corrosion/contamination, kinked housing, poor housing ends, frayed cable, etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jul 20, 2017 | Sram Force Double Tap Shift/Brake Levers
I just cant get used to changing gears,why is there two levers, one on each side of the handle bar.I end up with the chain coming off frequently.
Angie, Have patience. It will come to you. There are two levers, because there are two places where the gears change - in the front (by the pedals) and on the back wheel. You might find it easier to just use one lever. Do this--- have someone help you hold the bike so that the back wheel is off the ground. Turn the pedals on the bike and work one shift lever at a time so that you can see which lever is for the front vs. the rear. If you have three gears in the front (the correct name is chain-rings) then leave the front one so that the chain is on the middle chain ring. If there are two, then select the larger one. Now shift the back one (the gears back there are called cogs). You might have 5,6,7 or even 8 cogs back there. Practice shifting the back cogs to see what is happening. If you find that the chain comes off, even when you leave the front on on the middle chain ring, you need an adjustment. Good luck! Al K
Aug 12, 2011 | Shimano Cycling
I'm new to multi gear bikes..whats the reason for the 6 gear positions on the right and 3 gear positions on the left hand side
Bicycles have two sets of gears (front and back). The 6 position control slides the chain between the 6 sprockets (cogs) on the back. The 3 gears are for the front set of cogs. Between the two sets of sprockets, you get 18 (theoretical) different rates of chain movement per turn of the pedals. In fact some of the settings overlap. (However some of these should not be used. Do not use the settings that pull the chain to the furthest inside of one derailleur and the furthest outside of the other. This diagonal between the biggest and biggest sprockets (or smallest to smallest) puts extra strain on the chain.) The back derailleur is in the lowest gear when on the biggest sprocker. The front low gear is on the smallest cog. The highest gear possible is on the smallest rear cog and the largest front cog.
By planning the shifts in gears, you can maintain the same speed and cadence (rate of pedalling) on different terrains. (For going up a hill, use a lower gear than on flat terrain. However don't go to low or the bike may not balance well.) To shift through a large range of gears, you must be pedalling and then move the rear derailleur control followed by the front derailleur then the back again. (For faster shifts to a low speed, you can shift the front derailleur first but that can stress the system.)
For a guide to using the gears: http://www.southcoastbikes.co.uk/articles.asp?article=Gears .
I hope this helps.
May 14, 2011 | Huffy Cycling
Cannot get rear derailer to work properly 24 inch girls evolution
Don't start messing with the derailleur yet! Make sure your shifting trouble isn't due to something else, such as a warped, dirty, or stretched chain, gummed-up pulleys, crud in the cable housing, trapped cable, or a bent derailleur hanger
Clean the chain and the rear derailleur pulleys. Pull the chain away from each pulley, and turn the pulley to make sure it can move freely. A pulley that offers resistance to turning must be replaced.
Now check the cable to be sure it slides freely. Mud and grit within the cable housing, or on a cable-guide, can keep the derailleur from moving a "full gear" during downshifts. If the cable doesn't slide freely in the housing, you may be able to clean or lube it to restore smooth shifting.
Let the high-gear limit screw. In your highest gear on the shifter, and with the chain on the smallest cog, position the derailleur so the upper pulley exactly matches the teeth of the small cog. Run the chain a bit with the front derailleur in the large ring, adjusting the limit screw until the pulley and the cog seem to match perfectly.
Setting the high-gear (small cog) limiting screw.
Once you're sure the derailleur matches the cog, move it just a whisker (1/8 to 1/4 turn) towards the other cogs. (You may need to readjust a bit if you get chain-skip.)
Closeup of setting the limiting screw.
Now adjust the low-gear limit screw. Shift into the lowest gear (largest cog). If it won't go, loosen the limit screw. With the chain on the largest cog (and the front derailleur in the small chainring), adjust the derailleur so the upper pulley exactly matches the teeth of the large cog.Once it's perfect, turn the limit screw so it moves the derailleur a tiny amount towards the other cogs (1/8 to 1/4 turn usually works).
Setting the low-gear (largest cog) limiting screw.
Now shift to the highest gear (smallest cog). Push the shift lever to downshift one gear (go from the smallest cog to the next-smallest). If it doesn't shift, tighten the cable with the barrel adjuster, 1/2 turn counter-clockwise. Backshift and try again. Continue tightening until it shifts. If it overshifts, going from the smallest cog to the third-smallest, loosen the cable by turning 1/2 turn clockwise. Backshift and repeat until it shifts exactly from the small to the next-smallest cog.
Fine adjustment of tension in the derailleur cable.
Now go to the second-smallest ring. Tighten or loosen the cable slightly, until the outer side plates of the chain are just clearing the third-smallest cog. Shift up and down, fine-tuning until you're satisfied.
Checking the position of the chain on the cogs.
Mar 04, 2011 | Pacific International Pacific Evolution 24...
My shimno sora front derailler shifts perfectly to the small and large chain set cogs, but on the middle, the chain rubs along the cage.
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
i hope this helps
-matthew
Oct 30, 2009 | Cycling
Problem with chain and gears
Wash, degrease and scrub the chain and derailleurs with a good degreaser (like Simple Green). Dry the chain and relubricate it with an appropriate bike chain lubricant (not oil or WD-40). Shift the derailleurs to the smallest chain ring and cog on the cassette (low front gear, high rear gear) and then loosen the cable at the derailleurs, pull the cables taut and reattach them. If the derailleurs still need adjustment, here is a procedure for it:
Flip the bike over (so you can pedal the bike manually while you shift) and shift the front to the middle chain ring. Shift the rear to the highest gear (small cog). Release the cable from the pinch bolt on the derailleur. Adjust the screw marked "H" on the derailleur until the jockey wheel on the derailleur is aligned perfectly over the small cassette cog. Set the cable adjuster on the derailleur to the middle of its range (find this by screwing it all the way in and then count how many revolutions it makes until it screws out completely. Screw it back in one half of the total revolutions). Reattach the cable and shift to the lowest gear (the biggest cog). Over-shift and hold on the shifter, then adjust the "L" screw on the derailleur until the jockey wheel sits just past the last cog. You have to hold the shifter to do this. Now shift into the middle gear (or one of the two middle gears if the bike has an even number of gears) and adjust the derailleur using the barrel adjuster you previously set to the middle of its range. Adjust it so that the derailleur is sitting perfectly over the appropriate gear. Shift up and down the cassette while pedaling and in every gear, reverse pedal (freewheel) to make sure the chain does not hop. Adjust as necessary until all gears are smooth.
Now the front:
That should be it, unless there is another mechanical problem causing the missed shifts, like a bent derailleur hanger or damaged teeth on the cassette cogs or a bad derailleur. If it is still problematic, come back for further information.
i hope this helps
-matthew
Oct 26, 2009 | Cycling
Chain coming off fron gear when coasting or trying to pedal backwards? Local bike repair shop indicated that a bearing maybe shot but that they couldn't replace the front gear unit.
Oh, it is too bad you are in the Bronx. i'd have that fixed right quick. There are probably a pair of culprits at work here. One, your derailleurs no doubt need adjustment. Two, your rear derailleur hanger may be bent. These two can both cause the problem. Start with the rear hanger, because that will be easier to see.
Flip the bike onto the bars and saddle and take a look at your rear derailleur. Is it going straight up and down and is it aiming straight with your frame? If it isn't, you have found your problem. The hanger needs to be straightened. This can be done without any tools if you have a good eye. Hold the derailleur by the body and bend it to make the alignment good with the cassette. If this is NOT the problem (but i really think it is) then here is a walk-through on adjusting your derailleurs and hopefully this will solve it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 16, 2009 | Cycling
I'm trying to adjust the shimano gearing on my trek bike and am having a little trouble
Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Sep 02, 2009 | Cycling
I have a 1998 Gt Aggressor 26" bicycle. When shifting in the large gears, it hesitates before shifting or does not shift at all and just clicks. Can you help?
sound like the shift adjustment need moving or the cable to be adjusted from gear shift to the cogs there are a couple of ways to do this first select the low gear so the cable is slack and then look where the cable connects to the cog shift if you loosen the nust holding the cable and pull a little cable through retighten and try shifting.. if this doesnt work look at the way the guide moves the chain across if you see the guide stopping before the chain goes onto the cog look closely and you will see two small screws on the arm one is to stop the guide going to far to the right and one to the left look at the one on the right that shlould be the one for the transit to the large gear cog if you undo the screw half a turn then try the gear shift again see of it move far enough to put the chanin on the cog if not undo a little more.. these screws work for both the small and large cog shifting so the same can be done for the small cog if the chain keeps coming off.. Good Luck A
Aug 04, 2009 | GT Bicycles Cycling
I need to know how to place the chain back on the gears
shift onto your smallest cog on the rear and shift to your biggest cog at the front then place part of the chain onto the small cog at the back and then do the same with the big cog at the front then simply pedal forwards and the chain should go back on by itself
Aug 03, 2009 | Huffy Cycling
Sram 3.0 Comp Twister Front Mountain Bike Shifter - 00.0000.200.657 Logo
91 people viewed this question
Top Sram Cycling Experts
Michial Gueffroy
Mike
dante
Are you a Sram Cycling Expert? Answer questions, earn points and help others
