Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor Continually Goes Blank
My 17" ViewSonic continually goes blank after approximately 3 seconds. The monitor still has power and the green power LED remains lit. When I cycle the power button, the monitor turns off and on just as in normal operation. However, it continually shuts down after 2-3 seconds. I have tried the computer with a different monitor and had no problems so I don't think its the graphics card. I don't know what to check next, the transformer, monitor control/power CCA, other? I'm hoping for a quick, inexpensive fix, any suggestions?
I had a similar problem with a Westinghouse 19" LCD. Had left power on while running errands, but came home to a black screen. I could cycle the power and see the desktop image but it would go black after 2-3 seconds.
Out of curiosity, after cycling the power, I immediately pressed the monitor settings button, and was able to get into the menu . . ., no black out . . . I changed the brightness setting and crossed my fingers while I let the setting menu time out . . ., lo and behold, it's working again.
Perhaps Mark could comment as to why this might have worked.
. . . and yes, I do feel lucky . . .
Posted on Apr 23, 2008
  • 472 Answers
You are right in assuming it to be the monitor.
It is the inverter circuit that powers the backlights inside the LCD.
No backllight, no view. If you shine a bright light into the screen you will see it is still working, just not visible.
The Viewsonic range of monitors have a habit after several years use developing bad capacitors that need to be replaced. It's something that happens to most LCD's and alot of other electronics.. so not a design flaw, just age.
If you have modest electrical knowledge then its an easy job, If not then take it to your local TV repairman and have them do it. It should not cost alot to have it done. The main expense in this case is the labour.
Call a few shops in the area and get rough quotes to have it done. You will be surprised how much the cost can vary for the same simple job.
Posted on Apr 21, 2008
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Viewsonic VA721 - Screen goes blank for second or two and returns
Sounds like its going to sllep too soon make sure you do not have it set in your video card settings. also try it on a diffrent computer. if that does not shore it up replace the acpi board
Jun 11, 2009 | ViewSonic VA721 17" LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Jan 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
186 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
