Question about HP LaserJet CM1312 All-In-One Printer
I have an HP CM1312Nfi that when I power it on it will display the progress bar and will have the warning light flashing. The progress bar will almost finish and it reboot and restart the progress bar. No errors will display just the progress bar.
    Novelist:
  • 123 Answers
Hello Luis !
This problem is isually related to a hardware failure, commonly on the formatter (MainBoard), but there are a few steps you can do to recover it:
1) Make sure the printer is connected straight to the wall
2) Try doing an NvRam or Hardreset on the printer, for the 1312nfi just follow this steps:
a. Turn off the product.
b. Press and hold the Right arrow and Cancel buttons simultaneously.
c. Turn on the printer.
d. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
e. After a few minutes the printer should go back to the "ready mode"
3) If the printer goes back to ready, i would recommend you to download the latest Firware Update for the 1312nfi, you can download it from this link, just select you operation system from the list:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3562006&taskId=135&prodTypeId=18972&prodSeriesId=3558902&lang=en&cc=us
Now, if the printer is not comming back to ready just turn the printer off, and with the printer off run this firmware update on your computer and finally turn the printer back on.
If after all of this you cannot get the printer to work, that means the formatter board is defective and need to be replaced
Since this is a new hp model it may be still under warranty so you call HP Tech support 1 800 334 51 44 (US)
or take the printer to an HP Authorized repair center, heres a link to find one near to your location:
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Hope this can help you!
Bryan
eliteprintersolutions@gmail.com
Posted on Jul 16, 2010
49 SERVICE MANUAL
79 SERVICE MANUAL
Posted on Jul 24, 2010
    New Friend:
  • 12 Answers
If your HP CM1312nfi does not boot like this and just shows the blue and white progress bar AND the fax line is plugged in, try unplugging the fax line. It can be a damaged fax board - I had this happen to mine, cheap fix with a replacement fax board from HP.
Posted on Aug 25, 2014
WIl not print correctly
If it is faded, it could be the transfer roller. I've had great success with simply periodically cleaning it, then getting a good printout. See my solution for this already posted: Check out this solution to the HP Color LaserJet CM1312nfi Laser Color...
Otherwise, the other issue I had late last year was that it needed a new intermediate transfer belt (part #RM1-4436-000CN). You can find a good deal on one, and the instructions for replacement are on page 156 in the service manual: http://www.feedroller.com/Store/Service%20Manual/HP-CLJ-CM1312-MFP-Manual.pdf
It's not the hardest replacement ever, but needs 2-3 hours depending on skill, and a little patience.
Mar 28, 2014 | HP Color LaserJet CM1312nfi Laser Color...
Printer will not complete boot. It looks like it begins to boot, then power light goes out but comes on again
Most probably caused by a power supply failure or main board short. Either way it is not a repairable fault.
Jan 03, 2018 | HP Photosmart C5180 All-In-One InkJet...
Hp cm1312nfi printer problem error ready to download
The error is due to corrupt firmware and you need to reinstall it.
HP CM1312NFI Firmware Download & Instructions
Please visit the above link and Download the firmware.
"The HP Easy Firmware Upgrade utility provides the HP MFP firmware .rfu bundle and a user friendly method to transfer the .rfu file to the MFP all contained in a self-extracting executable for the Windows operating systems"
Please visit the above link and read all the instructions/ details and upgrade the firmware.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate MFP in the dialog window. If you assigned a different name to the HP MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the pc during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. The flash firmware update process is complete.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 09, 2011 | HP LaserJet CM1312 All-In-One Printer
Hp clj cm1312 mfp firmware corrupt ready 2 download, What to me to do? Help, please
You will need to apply the firmware to the machine. I've attached the link to hp site for you to download the firmware file as well. Below the link is the directions on how to accomplish this, as well you can see the same directions on via the link provided
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3558903&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=t2-85206-1
Firmware Update Notes:
  1. The Firmware Update Utility uses the USB connection to the printer.
  2. The HP Color LaserJet CM1312 MFP print driver software must be installed prior to using this utility.
  3. The HP Color LaserJet CM1312 MFP printer must be on and in a READY state as shown by the LCD display on the control panel and remain powered on during the entire firmware update process.
  4. Depending on the processor speed of your PC, the firmware update process may complete on the printer before the update status progress bar in the flash firmware update utility on the PC screen completes, this is normal.
  5. Once the update process has started, do not use your PC for any other activity until the process is complete.
  6. Do not power cycle the product or the PC until the firmware update process is complete.
Process:
  3. Double click on the file CM1312_MFP_Series_FW_Update-20100616.exe flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate CM1312 MFP driver in the dialog window. If you assigned a different name to the HP CM1312 MFP, choose the name that represents the correct printer.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Printing Document - Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  10. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100616
Oct 20, 2010 | HP LaserJet CM1312 All-In-One Printer
HP cm1312nfi control-panel display WHITE, it still...
Try doing a hard or reset or nvram:
1. Turn the printer off, disconnect the phone line
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If the lcd does not display anything contact hp or a local service provider as there is a definite power failure.
Al
Eliteprintersolutions@gmail.com
May 20, 2010 | HP LaserJet CM1312 All-In-One Printer
My c6180 when turned on displays a blue screen with the hp logo and a bar at the bottom. the bar shows loadup progress but suddenly a warning about not unpluging it from the wall appears and then it starts...
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers . 579e7fb.jpg
Jan 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP 7410 will not boot. It powers up and the HP logo screen flashe
This was solved really well on this blog. It is some problem with the wifi board. If you disconnect it (no so hard and well explained on the blog) you will have network printing over a cable but no wireless.
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
Oct 23, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 will not boot. It powers up and the HP logo appears on the screen with a progress bar. The display then scrambles and the power light flashes green. No buttons work or do anything.
connect the printer directly to the wall socket for the power supply if it is connected thrugh surge protector.
perform a reset :
unplug the power cable .
press and hold # and 6 key on the printer..
plug in the cable wait for 20 secs then release the buttons..
after this the printer will re-initialize .. this may take few mins..
and chek after that
Oct 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Ipaq 2490 hangs on booting
Try this:
4. Make clean reset (hold callendar + itask, then press and hold reset), after about two seconds you will hear knack. Now unhold these buttons. The screen will be black.
5. After that make hard reset (hold callendar + messaging + power and then press and hold reset) after about two seconds unhold reset button first and after about one seconds remaining buttons. You will see on screen PS FORMAT.
6. Now is you iPAQ ready.
Nov 24, 2007 | Computers & Internet
HP LaserJet CM1312 All-In-One Printer Logo
3,382 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
