Larry provides a great answer.
ENGLISH
I bought an AOC F 22+ monitor, after 2 months it started to turn itself off and its resolution was 1680x1050. They changed the motherboard on the service, but I still have a resolution of 1680x1050 and I can't get a bigger one. When I manually want to adjust the resolution, I can't because it's not active in OSD or iMeni. What should I do?
FIRST OFF THE MONITOR IS A SLAVE
THE PC IS MASTER AND IT SETS RESOLTION NOT THE MONITOR EVER. (BUT THE MONITOR DOES TELL THE PC THE LIMITS FIRST AT PNP PLUG AND PLAY)
F22 MAX IS THIS.
1920x1080x60Hz, MAX AND BEST..
IT DOES "only" !!!! THESE. MANUAL QUOTED.
1920x1080@60Hz
640x480@60/67/72/75Hz,
720x400@70Hz,
720x400@70Hz,
800x600@56/60/72/75Hz,
1024x768@60/70/72/75Hz,
1280x1024@60/75Hz,
1440x900@60/75Hz,
1680x1050@60Hz,
1920x1080@60Hz
THE PC GPU AND MONITOR BOTH/CAN LIMIT RESOLUTION MAX. (OR EVEN SPECIFICS)
NO PC TOLD NO ANSWER POSSIBLE EVER.
NO PC , NO OS, AND IF A GPU CARD UPGRADE NOT TOLD THAT. (DESKTOP?)
THE CURE IS A GPU CARD THAT DOES 1920x1080@60Hz
NOTE THE HZ LIMITS ON THIS MONITOR , DO ONLY THOSE OR IT FAILS.
A WORKING GOOD PC THE VIDEO DRIVER SETTINGS SHOWS THESE LIMITS. (COMBINED)
A GOOD VIDEO CARD IS gtx1050(NO VGA ) IF MUST USE VGA SAY SO. AND CAN FIND CHEAP GOOD GPU CARD FOR YOU, I CAN.
USE GOOGLE TRANSLATE TO READ THIS.
https://translate.google.ca/
