Question about HP DeskJet F380 All-In-One Printer
Scan and copy but not printing
I have re installed my printer twice and installed the drivers and its set on default it will scan and copy but will not print i can't print off line or on at one point it said error offline now it just says ready
  • Swahera Apr 21, 2008
    My printer scan and copy but not print. I uninstalled and try to re-install my printer but it not intalling.
For scanning
Posted on Apr 21, 2008
Unable to print files from windows 7
have you checked the setting if the machine is the default printer
Nov 11, 2015 | Sharp Mx-2310u Color Copy/print/scan
Why won't it print and why is the scanner not working?
step1: Check printer is powering on or not., if not check the adapter.
step2. Any error lights are blinking on panel?..check
step3: Cartridges are conditioned or not?.. if not,replace them..
step4: If every thing is fine, check for copying..if copying happens properly..go to next step.. or else go to step2 and check once again properly..
step5: check proper drivers in system., or else
step6: un install existing drivers.
step7: connect usb cable check for new hard ware found popup.. if not check usb cable..
step8:Install full feature drivers from below said link:
May 01, 2015 | HP DeskJet F380 All-In-One Printer
The scanner function on my Canon D480 has not worked since the installation.
Go to the scanner company website and see if there are drivers available for download. Sounds as if you may not have the proper drivers installed.
Jan 07, 2013 | Canon imageCLASS D480 Black and White...
My printer scans, copy but won't print from computer?
Did you set this printer as the default printer? To do this go to Start - Printer and Faxes, right click on HP printer, select Set As Default Printer. If you are not see your HP Deskject F340 there, that mean your printer driver is not installed. Please install your printer driver.
If you already set it as the default and it is still not printing. Restart your computer to try solve problem.
You said that printer scans so the connection between your computer and printer is fine. Problem is your computer doesn't take the printer as it's printer device yet.
Hope this will help. Thanks for reading
Jul 19, 2011 | HP Deskjet F340 All-In-One Printer
I just installed the printer. I see how to
Go to printer settings in control panel. Make sure this new one is set to default printer. And go to webpage or open a document, go to file, then print.
May 19, 2010 | Lexmark X4270 All-In-One InkJet Printer
Can not scan
With some of the HP all-In-One printers, the scan function will only work once the printer software (not just the drivers) have been installed on the connect machine.
Feb 03, 2010 | HP PSC 1315 All-In-One InkJet Printer
My Printer won't print. It scans and it copies. There are No ligh
1) If it worked before, you can do a system restore to the last time you remember it working which should clear the problem. Also, 2) Check your printer folder (in "Control Panel") and see if it is listed as a "printer" in there. You may need to reinstall the drivers if you don't see it, Sometimes the driver disk has a repair install option.
3) It may not be "check marked" as your default printer device (in printer folder) which you can easily change by right click on its icon and choose "set as default".
Sep 15, 2009 | HP DeskJet F380 All-In-One Printer
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Hello, I have a new Canon MP 610 all in one printer/ scanner/ copier. I have installed the software, downloaded drivers. It prints from the PC, makes copies, but it will not scan and save to PC. HELP !!...
in the printer control panel, you can set how the scanner handles the image. You'll need to tell it where and how to scan/save to pc, including folder location. Defaults are usually some obscure file type
Apr 24, 2008 | Office Equipment & Supplies
Printer not printing
try a test page, first, disconnected from printer..
and go get fresh set of printer drivers here
Mar 17, 2008 | Lexmark JetPrinter Z22 Color InkJet
HP DeskJet F380 All-In-One Printer Logo
238 people viewed this question
Ben Johnson
