Question about Xerox WorkCentre XD100 All-In-One Laser Printer
I have a number 4 and a letter H flashing - Xerox WorkCentre XD100 All-In-One Laser Printer
  • 1,110 Answers
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models
Good Luck and Thank You for using Fixya
Posted on Jul 16, 2010
The letter u key gives me the number 4, the i key gives me the number 5 the o gives me number 6, The last 3 to 4 letter keys gives me numbers
right first off im assuming this isn't a full size keyboard with the number pad on the right.
so when you have a laptop keyboard some characters share with others, in your case numb lock has been pressed and is replacing the letter u with 4
hope this helps
Jan 02, 2014 | Verbatim Keyboard, Mouse, Keyboard and...
Certain letter keys give me numbers instead of the letter on my verbatim wireless keyboard and mouse
Sounds like NUMlock, or another function key like that. Are those numbers on the keys themselves? That's a common problem for laptop keyboards that do not have number pads.
A letter and number appear alternately
What Letter and What number?. These usually come up as L - 1 or H - 4...both of which are easily resolved. Just let us know what code is flashing.
Feb 03, 2011 | Sharp AL 1631 Copier
1.This a no. between 1 to 10.To write it in words ,you need the same number of letters as itself. the number is-----------------\r\n2.find the odd one out 81,90,121,234 the answer is -----------------
ONE has 3 letters which does not match your criteria
TWO has 3 letters which does not match your criteria
THREE has 5 letters which does not match your criteria
FOUR has 4 letters
81 is 3 times 3 times 3 times 3 which is 4 numbers
90 is 2 times 3 times 3 times 5 which is 4 numbers
121 is 11 times 11
234 is 2 times 3 times 3 times 13 which is 4 numbers
So, the "odd" value is the one without the 4 factors.
Dec 24, 2010 | Microsoft Internet Explorer 6
Where do we find the honda engine model number on our Troybilt lawn mower?
a small flat surface...usually near the governor arm...the letter/number combination is "dot" stamped into the aluminum and kinda small....there will be a 4 letters and 7 numbers in a row...thats serial number...right above the 4 letters is 3 or 4 more, know as orientation numbers, that identifies usage...
Apr 18, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
I cant find the serial number to install the CD's that come with it
Its the numbers on the bottom of the camera. There is 3 sets of 4. Do not include the letters at the end. Should look like 1234 5678 9123 XX
Dec 26, 2009 | Canon FS200 Flash Media Camcorder
When the copier is turned on the letter H and the number 4 flashes can you tell me what this means please
Hello Karen; H-4 in sharp copier it means fusing unit problem,it could be reset ,the procedure depend on the model of the machine.
Jul 13, 2009 | Sharp Office Equipment & Supplies
Flashing ''4'' then ''H'' on my Sharp AL-1551CS
Disconnect printer from computer.
Switch on printer.
Type quickly: C "Auto" C "Auto", than 14 (number of copies) than "start"
"Auto" is the second button from the left.
Nov 16, 2008 | Sharp AL-1551 Laser Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
108 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
