Question about IBM ThinkPad R52 Notebook
I have a strange problem in my IBM r52 laptop... my laptop was working properly and suddenly its screen turn out white and switched off. After that when i again try to start my laptop it was not starting and no display in screen ...
  • Vignesh Ramamoorthy
    Vignesh Ramamoorthy Jul 16, 2010
    has to be a hardware fault..
  • amit0101_ver Jul 16, 2010
    when i switched it on again my laptop does not boot up ..
    my battery was charged..
Change *********** board
Posted on Jul 30, 2010
Thin vertical yellow line and a white vertical line appeared on ibm thinkcenter r52
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 10, 2011 | IBM ThinkPad R52 Notebook
Ibm r52 is working with battery, but the battery is not getting charged. Ac adapter is working properly.
Either bad battery or failed battery charging circuit on the motherboard.
You cannot tell which is failing without testing laptop with another known good battery.
Dec 15, 2010 | IBM ThinkPad R52 Notebook
My IBM R52 laptop displays some vertical thin lines (red,green,blue,white,etc). I noticed this problem arises basically IBM R52 and R80 models. Some of my friends too are suffering from this problem and...
This sounds similar to a fault i had with an old dell laptop... very thin vertical lines running the length of the screen. Unfortunately it was an LCD problem, the screen was kaput replacing the screen solved the problem.
To test if it is an LCD fault, simply plug your laptop into an external monitor... if you get no lines on external monitor then its a faulty LCD screen.
Is that solution genuine enough for you?
Aug 27, 2010 | IBM ThinkPad R52 Notebook
How do I turn on the wireless switch on an IBM Think Pad R52?
Not all R52's have the bluetooth/wireless option. If yours has it, there will be a light for it located somewhere around the keyboard or the bottom of the screen.
To toggle the wireless on press Fn+F5 key combo, the corresponding led should illuminate.
If it doesn't turn on then check in Device Manager. If there any "unknown devices?" in device manager it might be worth getting these downloaded and running:
ThinkPad Power Management driver, OnScreen Display utility and Wireless device drivers.
Reagrds.
Feb 22, 2010 | IBM ThinkPad R52 Notebook
When i upgraded the memory to 2G of memory, the screen will not turn on.
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot. If you have tried putting a single stick of 2 GB or RAM, it won't work.
Ensure you have purchased the proper kind of RAM. Also ensure the stick is seated securely and properly into the slot.
Good Luck,
NOLA Tech
Feb 05, 2010 | IBM ThinkPad R52: R52 P M 760(2.0GHz),...
IBM R52 laptop is getting stuck boot up
TRY AND REMOVE YOUR RAM AFTER THAT RESET THE MACHINE BY REMOVING THE SYSTEM BATTERY AND SHORT CIRCUITING THE BATTERY CONTACTS FOR 30 SECONDS MAKESURE THAT YOU'VE TAKING LAPTOP BATTERY OFF FROM THE MACHINE AFTER THAT PUT BACK THE RAM THE TRY TO SWITCH IT ON AGAIN
Dec 22, 2009 | IBM ThinkPad R52 Notebook
For thinkpad R52 where is the wirless switch ON/OFF?
On thinkpad R52 Wireless turns on and turns off by holding key Fn and pressing key F5.
Fn+F5
Aug 05, 2009 | IBM ThinkPad R52 Notebook
MY IBM Thinkpad R52 laptop is not entering in BIOS setup
OK< this is main fix I start with when working with a Thinkpad...Unplug from the AC adapter...remove the battery, and the cmos battery. That is the one about the size of a quarter. Leave them out for about 20 minutes. re assemble and try again...hope this helps...
Jan 25, 2009 | IBM ThinkPad R52 Notebook
IBM Thnink Pad R52 Shuts Down unexpectedly
it might be the battery, try plugging it in while doing that.
Jul 09, 2008 | IBM ThinkPad R52 Notebook
IBM ThinkPad R52 Notebook Logo
118 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
