Question about Toro Lawn Mower With Toro Power Tools
I need to change the 116183 belt on my toro mower
I need to change the 1116183 belt on my toro model # 74105 mower. What is the best way to get over the hydraulic line since the belt has to go on each side of it. Is it easier to to remove the hose at the pump or at the connector to the other hoses?
  • 147 Answers
SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
Posted on Nov 06, 2008
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
SOURCE: Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Posted on Sep 12, 2009
USMC ETECH
  • 60 Answers
SOURCE: have a toro 217d 1986 model with a 30562 62inch
THIS IS THE WEBSITE FOR THE MANUAL. SO FAR THIS IS THE ONLY SITE I HAVE FOUND WITH THE INFORMATION.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#manualsResultPage
I HOPE THIS HELPS IF NOT PLEASE LET ME KNOW AND I WILL FIND SOMETHING BETTER.
Posted on Feb 23, 2010
  • 36 Answers
SOURCE: I have a 22
clean with soap and water and put in sunlight to dry
Posted on Jun 05, 2010
I need to see a manual for the toro model 20370. I need to replace the drive belt
Take the old belt off and take it with you to a lawn mower shop or even a farm supply place that sells belts and they should mathch you up with the right belt.
Sep 05, 2014 | Garden
How to change the belts on toro timemaster
Type toro.com and the model of your mower they have schematics that will help you.
Jun 17, 2014 | Toro TimeMaster 30" Self-Propelled Lawn...
How to replace drive belt on toro recycler
First thing you need to do remove spark plug wire.. Then I would go to the website for Toro have the serial number ready there you will see the full picture of the way it is then go from there that's the best way with out seeing it. Good luck
Sep 15, 2012 | Toro Lawn Mower With Toro Power Tools
How to change the drive belt on a Toro 20016 SP Mower
The Toro 20016 mower is a front wheel drive mower and fairly simple to change the belt on. Start by disconnecting the spark plug to prevent start ups while working on the machine.
Remove the blade and adapter. The adapter includes the pulley for the belt.
two screws under the mower, with 3/8 heads hold the black cover over the belt. remove the cover and now you will see the transmission
The transmission, depending on the year of your machine will have a guard holding the belt on. Bend or remove the guard to remove the belt. Install you belt in reverse order.
You can get parts and special tools like the blade stop at a store like www.arcolawn.com
Feb 23, 2011 | Toro Lawnmower Lawn Mower Sp Drive Belt...
I have a toro lawn mower. Model no. 20352. The drive belt came off the pulley. How do I reinstall?
Go to this URL:
https://icontent.toro.com/smartmanuals/22Recycler/Proc10806.htm
On the left side of the page there are a few items for maintaining your mower. One shows how to change the drive belt for a front drive and one shows for the rear drive. Click on the one you have and it will show you how to accomplish this task. Be sure to either tighten the belt so it does not fall off again, or if it is bad, replace the belt. Please follow all safety instructions.
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled mower will not move
Nov 06, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
44 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
