Question about Apple iPod nano
Ipod was exposed to water
I dropped my ipod in the sink, and now it won't turn on. But it will operate when it is plugged up to my ipod dock, or computer.
  • Apple Master
  • 13,433 Answers
Pluging the ipod into the computer while wet will damage the device further, take it a part and dry very carefully.
Posted on Apr 21, 2008
My kicker iPod docking station displays aux-in and won't play the iPod there is nothing plugged into the aux jack point
Turn rotary control counter clockwise to disable auxiliary input. When auxiliary input is disabled , menu will display "--".
Jun 30, 2012 | Kicker IK150 Digital Docking System w...
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
Black won't print for my epson SX515W
I have solved this problem on my sx515w. I hadn't used the printer for a while and when I did after about 3 months the black wouldn't print. Even after trying several different new cartridges, driver reinstals, updates, automatic head cleaning operations..... It turned out that the printer head had ink dried onto it due to lack of use.
What you need to do is to drop a few drops of nail polish remover (yes as in Acetone solution) on to the foam cleaning dock, located to the far right of the printer rail. When the printer is resting, the ink jet module covers the dock. TO expose the dock, set the printer to the 'clean head' operation and the ink jet module will go to the far left, when this happens pull the power cord out so it stays out of the way (don't worry the printer will reset fine afterwards).So now the module is out of the way drop in some cleaing fluid on to the sponge dock. Then you are ready to run the automatic clean head operation at least 20 times. Do a test print each time until full print quality is resumed.
Oh and it is worth cleaning the sponge dock with tissue as it gets heavily soiled with ink (using the 'clean head' - turn off half way operation just described above). Remeber to replenish the nail polish remover. This should sort it.
Yackshimash.
Cheers
Oct 03, 2010 | Epson Stylus CX6600 All-In-One InkJet...
My 2g ipod touch is bricked on the apple screen and i dont know what to do
Your ipod can go into paper weight or brick mode after dropping it or exposing it to moisture ie. water. Look down the headphone jack with a flash light and see if the little rectangular water sensor is white or pink. White means that your good and pink means the water sensor has been triggered and the unit has been exposed to excessive moisture. Here's the kicker- Apple's 1 year warranty does not cover water damage so your fu.kd. But if your still within your year warranty or you got an extended warranty, then just take the thing back to the Apple store and exchange it out if the water sensor is not pink.
Oct 03, 2010 | Apple iPod touch
If an iPod has been dropped in water, is it possible to turn it back on again?
DO NOT TURN IT ON WHILE IT IS WET!!
Try to shake all the water out of it that is possible by shaking it out of the earphone plug hole, and the docking station hole at the bottom.
If you can get some silica gel, put your ipod in a plastic bag filled with fresh silica gel and put it in a warm place for about a week or so.
If you cannot get silica gel the after removing as much water as possible put it on a warm surface (TV.etc) for a few weeks, then try to turn it back on.
This works most of the time.
Good Luck, I hope this helps
Please Rate Me, Thanks
May 09, 2010 | Apple iPod touch
Ipod touch wont turn on,sync,charge,restore, or anything.
Your ipod is in paper weight mode because you either dropped this thing like a bad habit or exposed it to water.  This thing is like a cat and hates water.  Take the thing back to the store if your within your 30 day return window or take the thing back to the Apple store if your within your year window.  The Apple folks will give you a brand spankin new one if they can't figure it out, but they won't give you sh.t if they find out you water damaged it or dropped it.
Oct 31, 2009 | Apple iPod touch
I need to open a JBL onstage II speaker system to reattach the ipod dock, i can do that, it just doesn't seem to open
you have to remove the 3 sticky pads in at the bottom of the speaker and there you will expose all the screws that need to be removed...there is also one where the batteries go
if you have any luck replacing the ipod dock let me know please
Oct 17, 2009 | JBL ONSTAGE Docking Station for iPod
I dropped my On Stage micro and now when my iPod is docked and the on stage is powered on their is a LOUD buzzing sound from the speakers. The auz-in mini plug still transmits sound and music fine, only...
I have had then same exact problem, except I had an ihome. I've done research on it for a way to fix it. basically what I have come to find is that the plug for the ipod is just cheaply made, and that there is basically no easy and cheap fix for it. However as long as you have an aux-in you can just simply avoid the problem by buying an eighth inch to eighth inch cord so that you can just simply plug you ipod into the aux-in. As long as you have the ipod plugged into the the aux-in, and aux mode is selected, it should play your music while charging.
Sep 21, 2009 | JBL On Stage Micro Speaker Dock for Apple...
I dropped my ipod touch in the sink and it now it doesn't work
to fix this, you're going to need your ipod, a plastic zip-lock bag, and uncooked rice. first, open the bag and fill it halfway with uncooked rice. then put your ipod in the middle of it all. then zip the bag and let it sit for about a day. the rice should have absorbed all the water by then. most of the times, this will work. but sometimes, the ipod is damaged beyond repair by the water. good luck
hope this helps ;-)
Apr 04, 2009 | Apple iPod touch
IPod Nano 3rd Generation
Hello Nada19,
The dock connector is the connector at the bottom of the iPod which the USB cable you use to connect the iPod to your computer plugs into. This is also the connector that is used to connect your iPod to a "dock" such as this one. An iPod dock, like this one is a device that you drop your iPod into for charging. It typically also has a connection for external speakers that can be used with the dock.
Not all models of iPod have a dock connector. And the actual layout of the dock connector varies from model to model. It sounds like you will need to use an iPod model that does have a dock connector to interface with the karaoke machine. You may also need an interface cable. Consult the documentation of your karaoke machine for more detailed info.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 01, 2008 | Audio Players & Recorders
Apple iPod nano Logo
57 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
