Question about GE (PSS26MSRSS) Side by Side Refrigerator
I am on my third dispenser light bulb Unit is less then two years old.OEM bulbs are not available from local GE stores and bulbs from Big Box stores will not work.What can do? Service Call is $69.00
Dispenser Light
From Button Box,
adid not have time to work on the light problem,will need some time,but will give it a try.Thanks for the info.
BB
Posted on Apr 23, 2008
    Genius:
  • 1,073 Answers
Need to change the light bulb socket
Posted on Apr 21, 2008
How can I fix a dim light bulb on an ice dispenser?
The dispenser bulb looks similar to a c7 christmas bulb or night light bulb but they are not the same. The dispenser bulb on some are 6 volt and some are 12 volt. The night light bulbs are 120 volt and will light very dim. Make sure you got the correct bulb from an appliance part dealer. They will need your model number of the fridge. Or check on line parts stores like www.vvapplianceparts.com.
Mar 04, 2016 | GE Profile Arctica 25.4 Cubic Feet...
No light in door dispenser
The light bulb is located in the top panel just above the dispenser and to the front. Be sure to check the manual for bulb voltage, most of these used a 12 volt bulb and NOT a 115 volt. It looks like an old style small base Christmas tree bulb.
Mar 21, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
I have to replace microwave light bulb. It's GE counter top Microwave JES1142PSE model. I hace opened the microwave and have located the bulb,but could not unscrew.I don't know needs to be pul
That exact model number is not showing up, so you may want to check the tag on or in the unit and look here for parts.
Most of the models in this class of ovens were not really made to be serviced, so GE only makes the turntable parts available.
It also sounds like your bulb is an assembly - the socket and bulb and one piece.
So your local appliance parts store should have a generic replacement for it. You should take the bulb.
Be careful when disconnecting the leads.
Apr 14, 2013 | GE Microwave Ovens
I need to know what replacement bulb to buy to replace light on dispenser?
on the parts list for that bulb is says its a 12 volt screw in bulb w/a base like a nightlight bulb..the OEM part number for it is WR02X12208
i suspect if you took the old one to LOWE'S or HOME DEPOT they will have a replacement in stock. The thing to remember when getting one is that it is 12 volt and not 120 volt
If you wanted to order one to be sure to get the correct one your local appliance parts store would have one or it could be ordered online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Aug 28, 2011 | GE GSS20IEP Side by Side Refrigerator
Where can I get a light bulb and base for Magic Chef microwave model #MCP13E1ST?
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Just take the old one with you.
Dec 06, 2009 | Magic Chef MCD1311ST Microwave Oven
I need to know what bulbs I need fo rthe GE
main bulb is ge part # AP2006861 and is a 60 watt common light bulb/the dispenser bulb is a g.e. part # of AP3884244 and you should be able to get these at a grocery store or ace hardware
Oct 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Need to replace the surface light in GE JVM1490BD 003
Or you can find helpful exploded view diagrams and order parts by entering your full model number here.
You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jun 28, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
Water and Ice dispenser quit functioning
the solution to this problem is so simple it makes me laaugh out loud. the bulb in the door that illuminates when a glass is placed under the water dispenser draws too much current when it gets old. just remove the bulb and it will work fine. you can then replace the bulb whenever you find it at a hardware store. I had the same problem, and spent hours online looking and was ready to buy a new motherboard to fix it. I have alot of faith in GE, and all of the bashing is a horse ****. GE makes turbine engines that power alot of the airplanes we fly in and i think they know a thing or two about engineering.
Jun 10, 2009 | GE Profile¿ 26.5 Cu. Ft. Stainless...
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
143 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
