I have an external drive I use and I network it between 2 computers. When My electricity goes off or my computers shut down for software updates the connection is lost. I need to know how to reconnect the network without calling a service tech every time.
  • 4,281 Answers
If you connect external drive with 1 computer with usb cable Then open my computer then you can see your external drive there right click on it then click on sharing then Click on "if you understand .... share this drive" then enable file sharing and enable all user can change files"Then apply .
Then go to other computer and go to start ->run or press windows key +R so you can see run type in "\\192.168.1.2" without "" where 192.168.1.2 is your computer ip where the external drive connected.
Then press enter then you can see share drive right click on it then map network drive and enable "reconnect at next logon" then you can see always in my computer.
For knowing your computer ip type in "cmd" without "" so you can see command prompt then type in prompt "ipconfig" then press enter so you can see your ip.
But if you connect drive with ehenet lan cable just not down your external drive ip and follow same above procedure to connect drive this time ip of harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jul 16, 2010
How do i install internet ti sylvania mini note book
There are three basic solutions for installing software on a netbook without an optical drive:
1. Share the Disc Over a Network
Required: A network, and a PC with an optical drive
This solution essentially shares the optical drive in one PC over a network to your Netbook. For most this is the easiest method because most users these days have a network readily available, and assuming there's a network there's likely a PC with an optical drive connected to it.
First you need to load the CD/DVD into the optical drive in the PC. Now go to My Computer and right click on the drive with the loaded media, click properties, navigate to the Sharing tab (note if you haven't done this before it may give you a warning that you shouldn't do this unless you know what you're doing, click the message to continue). Check the Share this folder on the network box, give it a name of your choice and hit OK.
From this point forward any computer on your network will be able to access the shared drive. If this is a problem be sure to follow the steps above and uncheck Share this folder on the network, to take it off.
Now, make sure your Netbook is connected to the network (this works wirelessly or through ethernet wired connection). Access My Network Places, and click Add A Network Place, use the wizard to add the optical drive you selected to share.
Now that it is shared you should be able to access it from My Network Places at any time (when your Netbook is connected to the network), and it should automatically refresh if you switch the CD, if it doesn't do a right-click, and hit refresh and the files should update. If you are trying to install software and are used to auto-run, double click the Setup.exe file or similar to begin installation.
2. Use an External Optical Drive (can be a bootable disc)
Required: External optical drive
External optical drives are the easiest way to use CD/DVD media and install software to your Netbook. It is however the most expensive option.
External drives are very simple; just plug it into an available USB port. Your Netbook will automatically detect the drive and simply add it to My Computer just like a built in drive. Some drives will even run power through the USB, while this makes them more mobile it eats up your Netbook's battery faster, if that is a problem other external drives do require a power outlet for use but should not drain your battery.
3. Create an Image (not bootable)
Required: Image making software (like Alcohol 120% or VirtualDrive), image emulation software (Alcohol 120% includes one, Dameon Tools is another, or Power Iso), access to a computer with an optical drive, and a method to transfer a large file from that computer to your Tablet PC.
You will need to use your particular software User-Guide for most of this process. What you do essentially is use software to create an exact copy of the CD in the form of a file (normally a .iso) that has to be read by an optical drive emulator which then can access the CD as if it were being read by a real optical drive. The biggest disadvantage to this method is that CDs can run around 700mbs, DVDs around 4gbs... transferring files of that size, even over fast networks, can be tedious. A benefit however is you can carry important CDs (as files) with you as you go, so for example if you need to install Microsoft Word content to use some feature while your in a meeting, you can do so without having the physical CD with you... This however of course requires heavy disk space since the CD file tends to be around 700mbs.
Hope this helps.
Dec 28, 2010 | Sylvania G-Netbook
You cannot vote on your own post 0 a blue screen of death states a problem has been detected and windows has been shutdown to prevent damage to your computer technnical imforation...
Important notes
First, the condition experince with networked computers
The computer has encountered a critical error due to a network server shutdown during when operating system update were being performed.
Second, the condition experince while attempting to install a malfunct computer software. Examples include, softwares capable of alterating the operating system. Attempting to install another operating systems software on an already existing system that is incompartible would first ease the prior system making way for the new version. A critical error shut down displaying digits is what occurs.
Third, attempting to restore the computers softwares byy deleting a significant program file, especially on the operating system causes the situation experinced.
Resolution to the problem
First, perform hardware checks
1. Disconnect the computer from any networks
a. if a computer connected to a network malfunctions, disconnecting each computer leaves the remaining to continue to function like before.
2. A problem due to connecting a device that was incompartibility to the operating system, with disconnection should produce restore functionality. examples, of printers, fax machines, and pheriperal connections that are outdated in software compartible to the computer system.
3. The foreign disk incompartible to the operating system locable in the disk driver once removed from the dirvers should restore to usual functionality soon after restarting the computer.
Second, perform software checks
1. Power of the computer, powering back on after mometary delay.
2. the computer should load display the usual operating system.
3. The process would display the same error indicating a persistant problem requiring reestablisment.
A comprehensive resolution of the problem considering both hardware and software conditions explained
1. Disconnect every computer pheripheral, examples, faxes, printers, speakers, external networks, internet modems
2. power off, power on shortly after
3. wait until the compuer performs a new reconfiguration to the removed pheriperals
contact technical support
Dec 20, 2010 | Computers & Internet
Mac cannot see 750GB maxtor 4
Did you disconnect the firewire drive before installing? You may need to update your firmware. Also, try these things:
1. Shut down and disconnect your firewire drive leaving nothing is connected to the firewire ports.
2. Restart, and use Disk Utility to repair permissions on your internal.
3. Shut down, and disconnect the AC power from the computer and your drive; also remove battery if laptop.
4. Let computer sit unpowered and disconnected for15 minutes.
5. Reconnect AC power to only the computer and reinsert battery.
6. Restart computer.
7. Verify that firewire ports are visible using System Profiler.
8. Reconnect your firewire drive, and refresh window in System Profiler to rescan the firewire bus, and confirm that drive is visible.
9. Repair disk and permissions on the firewire drive.
Dec 13, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Hi,\r\n When i plug in my Western Hard Disk WD4000ME, its detected by the system and all files are shown, but I cannot copy those files back to the system. It gives the following error:- "The requst could...
An I/O error indicates an issue with the device driver(s) that handle input/output processes such as copying files to/from hard drives, data in resident memory (RAM) waiting to be processed by the CPU or the controller chipset that handles the primary calls to/from the subsystems or a faulty hard drive.
Below are a few solutions that may help resolve the issue and allow you to transfer your files:
Before proceeding, you will need the following:
A. Computer B. External USB Hard Drive C. USB Cable D. RAM Module (Replacement, if necessary) E. Hard Drive (Replacement, if necessary) F. USB Hard Drive Enclosure (Replacement, if necessary) G. USB Cable (Replacement, if necessary)
Note: Solutions B/C apply only to Windows OS.
Solution A. Faulty USB Cable
1. Replace the USB cable. 2. Connect USB hard drive to the computer. 3. Attempt to copy a file from the drive. 4. If successful, copy additional files, as needed. If not successful, skip down to Solution B, step #1.
Solution B. Locked I/O Processes
1. Press and hold the power button on your desktop/laptop for about 10 seconds (or until the system has powered off completely). Then release the power button. 2. Make sure the USB drive is plugged in. 3. Wait another 10 seconds and press the button once again to power on the computer. 4. Once logged in, attempt to copy a single file from the drive 5. If successful, go to step #6. If not successful, skip down to Solution C, step #1. 6. Continue to copy files from the drive. Make sure to pay attention to what files (if any) prompt the I/O error message. If you receive an I/O error, skip down to Solution C, step #1.
Solution C. Motherboard Device Driver Installation/Update
1. Click on the "Start" menu and click on "Control Panel". 2. A new window will open, double-click on "System". 3. A new window will open, click on "Device Manager". 4. A new window will open, listed in the hierarchy are all the hardware components installed on the desktop/laptop. Look for any devices that display either a red "X", yellow "!" or yellow "?". These devices have either incorrect, incomplete or missing drivers/software and need to be installed, as they might be the root cause of the trouble. 5. If any of the above icons are present, perform a Windows Update by visiting the site below:
http://update.microsoft.com
Perform any updates available on the software and hardware side. 6. Restart your computer. 7. Follow Solution C, steps #1-4 to determine if any drivers still need updates. 8a. If updates are not needed, attempt to copy files from the hard drive. If successful, go to step #9. If not successful, skip down to Solution D, step #1. 8b. If updates are needed, you may need to visit the support site for your desktop/laptop's make/model and download any missing drivers. 9. Continue copying files, as needed.
Solution D. Faulty RAM
1. Power off the desktop/laptop and disconnect all cables. 2. Open the desktop/laptop. 3. Remove all the existing RAM. 4. Install the replacement RAM. 5. Power on the desktop/laptop. 6. Connect USB hard drive. 7. Test by copying some files from your hard drive. 8. If successful, close your desktop/laptop and continue copying files, as needed. If not successful, remove replacement RAM and reinstall previous RAM and skip down to Solution E, step #1.
Solution E. USB Hard Drive Case Faulty I/O Board
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install hard drive into replacement USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, skip down to Solution F, step #1.
F. Hard Drive Malfunction
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install replacement hard drive into USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, this could be an indiction of a much larger problem in the form of a Motherboard issue.
If the motherboard is malfunctioning, this is a sign of bigger things to come and will require a replacement board in order to correct.
In the event that the motherboard needs replacement, depending on the make/model of the desktop/laptop, the cost could range from $35-120 for 3rd-party boards or $85-300+ for consumer-level systems from manufacturers such as HP, Dell, etc. and $350-1000 from Apple.
If your desktop/laptop is still covered by the manufacturer's warranty or 3rd-party extended warranty, any hardware component that needs replacement should be covered at little to no out of pocket expense to the end-user. This also includes the external USB hard drive, as well.
Aug 15, 2010 | Western Digital Passport 320GB External...
My laptop whene i turn it on it starts to update thene it will say shutting down . and thene it starts to update again
You have been attacked by a virus. Total take over!
Just find a way to slave your hard disk, either as an external or over a network.
From a computer with an Antivirus software that is updated, scan the disk and eliminate all viruses found.
When done, backup your files and format the hard disk.
Then, use a bootable CD to setup the system again.
Apr 03, 2010 | Gateway MT3705 Notebook
I have 500GB SimpleDrive USB 2.0 External Hard Drive, but currently i am facing some problems with it. When i plug it in to my computer, the computer says that unknown device. and it also does not come to...
I would unplug the external drive then shut down your computer. Plug the drive in(be sure the USB port is in good working order.)Turn the computer on. If it does not recognize the drive search online for tech support for that particular drive. Install any drivers or software. Be sure to find out if the drive is compatible with your operating software. Make sure all connectors are seating firmly and correctly. Make sure that everything is plugged in where it should be plugged in.
Feb 15, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Datas get corrupted when loaded to 32gb kingston pen drive
I've seen a number of these flash drives get ruined when they're just jerked out of the USB port without shutting down the "Safely Remove Hardware" option in XP. No idea why, they just quit working. You should always go to the bottom right side of the tool bar and click on the Safely Remove Hardware icon and shut the device down before removing it. I think when you do this it shuts power off of the device so it doesn't arc electrically when you pull it out.
Oct 01, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I ilke to download the bug
There is no "magic bullet" software that will "kill" the malware on a compromised computer.
The "Best Practises" approach for dealing with an infected computer is:
1. disconnect the computer from all networks;
2. backup all your files (CD/DVD writable, external hard-drive, or USB memory stick);
3. reinstall the Operating System, from trusted media;
4. enable the Windows Firewall;
5. connect to the network;
7. download/install anti-virus software;
8. run Windows Update and Microsoft Update, to get all security patches;
9. reload your files from the backup.
Jun 01, 2009 | 3Com Computers & Internet
Freecom Hard drive
Backup file in windows is being compressed the bytes from the original file. YOu don't need to worry unless everything doing good.
Please rate me solved if you like my solution.
Best regards,
Philip
Oct 31, 2007 | Computers & Internet
Open Questions:
How To Write Archaeology Research Papers, Term Papers & Thesis? Archaeology term papers and research papers mostly follow the APA or Harvard style according to the requirement of the paper and on the word count. Writing an archaeology paper can seem a daunting task when toy are new to the field itself or have just started learning regarding a new site or culture. But it doesn't need to be so. To learn extensive knowledge about a specific topic To collect information from extensive sources and compile them To come up with conclusions To ensure that there is no plagiarism in the paper. The brief guide for essay writing given below will ensure that you get a well-written paper. Pick a Topic Your professor has asked you to write a research paper on an archaeological site or culture but you are unsure what to write on? Here is the sequence of tips to come uo with the perfect topic for your research paper. Conduct Background Research Literature review is one of the most important parts of background research. It is conducted by an archaeologist before initiating archaeological studies in an area or at a site. The same tips are also applicable towards finding articles and books regarding a topic. Reading Your Background Research We know you are in college and know how to read properly. Still, when it comes to the importance of understanding an issue thoroughly and synthesize the knowledge gained from reading, avoiding plagiarism and giving your opinion and conclusion, you would be advised to take some help. Writing a First Draft Writing a first draft for your research paper in archaeology doesn't have to be a daunting process if you take one step at a time towards preparing your draft. Writing and Editing Your Final Draft Writing a final draft of an archaeology research paper is undoubtedly the hardest part since writing styles vary between people so much. The recent history of archaeology suggests that the field has been increasingly moving towards professionalism and an ever increasing number of tools and techniques to use with the intention of get as much information as possible on a site that is examined. There is no one single theory of archaeology and any attempts to define the field has been unsuccessful because of disputes regarding their accuracy and relevance. During the middle of the twentieth century archaeology was thought to be closely tied to anthropology and history. In essence, archaeology itself is based on the study and examination of human cultures through the processes of recovery, documentation, and finally analysis of material remains as well as environmental data such as architecture, bio-facts, human remains, landscapes, and artifacts. The primary goal and purpose of archaeology are to document and provide an explanation regarding the origins and development of human culture, its chronicle evolution and develop an understanding of the history of culture. It also intends to study human behavior and ecology with regards to both prehistoric as well as historic societies. In the US, archaeology is considered to be one of the main sub-fields of anthropology. The study of archeology is a science and a humanistic endeavor. The goals of archaeology are far and wide and there is ongoing debate regarding its aims and responsibilities to the society. One of main goals on which there is some consensus is that the field intends to document and provide explanation of the origins as well as development of human cultures. Archaeologists also study the various methods used in the discipline and the theoretical and philosophical ideas that underpin the questions that inspired questions archaeologists in the past. The tasks of surveying regions around the world to locate new sites and excavating them to recover cultural remains, to classify, analyze and preserve are the most critical parts of an archaeological process. Each of these parts provides a great amount of information regarding a culture and the past. As such there is a need to present professional research papers and term papers that have to be written in the study of archeology.
Feb 23, 2018 | Final Draft Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
