Question about Kenmore 64902 Electric Dryer
My dryer heats up for about 30 seconds then there is no heat all
  • 57 Answers
Sounds like it's going off on a high limit switch. Check and make sure the exhaust flex hose is clear all the way to outside and make sure lint filter is clean. If all is clean, you may have a bad limit switch.
Posted on Jul 16, 2010
Frigidaire AEQ8700FGO dryer will run (and heat) for about 30 to 60 seconds then stop. 3 lights above start button will flash rapidly. Depressing cancel and start buttons at same time will not work for...
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Sep 30, 2013 | Electrolux AEQ8700F Electric Dryer
Maytag Dryer Model med5630TQ0, run it for 30 minutes works great run a second time for 30 minutes it automatically shuts-off and than I have to wait until it cools off to use heat option
Try cleaning out the vent in the wall and also check the vent hose to ensure its not kinked. If good air flow coming out of vent on back of dryer while running you could have a bad motor. Have to be disassembled to check it professionally.
Sep 25, 2017 | Dryers
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 28, 2011 | Dryers
Hello there ,I have a model lgn2000pw1 gas dryer it has quit heating. I have looked at the exhaust hose it is clear. the glowbar will come on for about 7 seconds and go off it will repeat this every 30...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 02, 2011 | Whirlpool Dryers
DRYER HEATING COIL LIGHTS FOR ABOUT 30 SECONDS AND CUTS OFF
heatman101]=-=-
Feb 22, 2011 | Estate TEDX640JQ Electric Dryer
Dryer starts to heat up and then heat element stops after about 30 seconds. if i reset the breaker it will do the same. if i just restart it soes not try to heat up
I would say it may be the Thermal Fuse here is a website to check it, and how to open the dryer. of course on the site the other things that may cause no heat: heating element, thermostat, and timer motor. it will show how to test these,also. Hope this helps Tim
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 25, 2010 | Whirlpool WED5200T Electric Dryer
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Stops after 20-30 seconds but only when using heat. Can immediately restart.
rbf, in looking Im not finding a 649732, but I do find a 649723. This dryer has a even heat board but also a thermistor. If you had to hold the start button for it to run, I would suspect the even heat board. That's not the case so Im suspecting a open or shorted thermistor. If you remove the lower panel it sits right behind the blower housing next to the thermal fuse. Should be black in color. Part number 3976615. The thermistor should ohm out at about 10k ohms plus or minus 3. When one of these thermistors fails usually you get the symtom your describing. Catriver.
Jun 23, 2007 | Kenmore 64952 Electric Dryer
Kenmore 64902 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
