Question about Kenmore 64802 Top Freezer Refrigerator
The freezer and refridgerator not working
The freezer and refridgerator codes on my admiral side by side both show - and will not turn on
  • 6,784 Answers
HI. You have stated that there are codes present, but you have not posted them on this page. Please post the codes, and the entire model number. I suspect that your main PCB has failed.
Standing by...
Posted on Jul 16, 2010
I have an older admiral refridgerator, when you open freezer it sounds like water dripping on a hot skillet. I unpluged it, later pluged it back in and wont come on
The sound was water dripping on the defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
Admiral Side/Side model MHG671581 fridge side not cooling enough, freezer side better. Need refridgerant?
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 08, 2010 | Admiral Refrigerators
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Admiral refridgerator freezer works fine but cooler section not cooling. had ice in back of cooler section.
it may be a timer and a timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32 also ...do not damage coils with freon in them
Aug 25, 2009 | Maytag Admiral Top-Freezer Refrigerator
Side by side Admiral freezer that has frost
Check condensation drain line for a blockage.
May 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
No cold air n at all in refridgerator or freezer oadmirall sideo
I believe i just posted part of your answer and mine, switch icemaker switch to off position and noise stops i'm assuming ice maker has had better days but hope it can be remidie
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
Trubleshoot refrigerator staying cold enough
First review the troubleshooting steps in the instruction manual. Check the freezer and frige temperature setting control knobs. Make sure the fan, coils, compressor etc. are clean. Check the door seals, especially at the bottom. If all that does not work, do some more online research (which is what I'm up to right now because I am faced with the same problem).
Sep 02, 2008 | Admiral 26 cu. ft. Side-By-Side...
ADMIRAL REFRIGERATOR/FREEZER BURNED
admiral is a maytag owned company which is now owned by whirlpool. so contact maytag or whirlpool. google them should be eay enough to find..
Nov 02, 2007 | Admiral 26 cu. ft. Side-By-Side...
Kenmore 64802 Top Freezer Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
