Question about Ovens
I have a 1960s ge P7 self cleaning wall oven that's making a loud buzzing noise when it is on to bake. It makes no noise when it's in the cleaning mode. How do I stop the noise when the oven is on?
3 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: 1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
Posted on Jan 15, 2009
SOURCE: GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Posted on Aug 05, 2009
Testimonial: "thanks!"
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Why won't my GE P7 self cleaning oven get hot??.. When switching the oven on.. The indicator light does not come on.. but if I position it half way between off and bake ,the light comes on but no heat...
Could have a bad element in oven.or the selector switch could have a short electrically. I would shut the circuit breaker off and call an electrician to check it out.could cause electrical shock or even a fire.
May 17, 2014 | Ovens
Need to know how to set self cleaning ge p7 self cleaning oven
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Sep 24, 2010 | GE Ovens
Can't get the GE P7 door lock engaged in order to
have to have a repairman come out and reset the code on the inbord computer not a simple fix i know i sell appliances
May 17, 2010 | GE 30" Built-In Single Electric Wall Oven...
I have a 1960s GE P7 oven that will not heat. How can I test the WB 22x53 switch? Could it be the latch release switch or the oven temp rheostat? The oven makes a humming noise when the dial is turned...
you can test any switch or relay or capacitors on the control board with an ohmmeter in the ohm setting. If low or no resistance, then it is bad. You can get any parts and manual at repairclinic.com or appliance411.com
Oct 14, 2009 | Ovens
Jul 15, 2009 | GE JKP50SH Electric Double Oven
GE electric range with self cleaning oven. When
try to unplug power from wall and wait 30 min,then turn on
Jul 05, 2009 | Ovens
Feb 18, 2008 | Ovens
Ovens Logo
128 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
