Question about Canon imageRUNNER 5000 Copier
How do i move the tray? and where do i find the waste toner container?
  • 1,219 Answers
the waste toner container is located at right sideway of copier in right lover corner covered with plastic cover with one screw.
Wich tray do you want to move?
Posted on Jul 16, 2010
  • 1 more comment
  • maggie_tavar Jul 16, 2010
    both trays on the collator they went all the way up and now I cannot get them back down help please!!!
  • Canon tech CROATIA
    Canon tech CROATIA Jul 17, 2010
    you need to remove covers around the trays, and manually rotate gears.But I think that these isnt only gears trouble...
  • maggie_tavar Jul 19, 2010
    I still cannot find the toner waste container. I have looked where you told me to and cannot find a thing! I will try the tray now
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
I'm having a display in my Minolta printer saying "waste near full"
If it is the waste toner bottle, you need to swap it out with a new one or carefully empty it into a plastic bag, be sure the plastic bag is sealed around the container or you will get toner everywhere! Or it could be waste in your finisher, like the staple debris tray or the hole punch debris tray, both are easy to access and empty
Mar 22, 2014 | Konica Minolta Office Equipment & Supplies
Need to find the toner waste container
The waste toner container is located behaind the panel below where you put the toner in. You will have to remove 2 screws. One is located in the hole you see behind the toner access door. The other one is located on top of the shelf to the left. If there is a finisher you should see a access hole to get to the screw. The panel will then have to be slid to the left and moved out of the way. You should then be able to see the waste toner bottle. Reverse everything and all should be good. Now if there is an error code associated with this you will have to go into service mode and do a waste toner clear.
Sep 22, 2011 | Canon imageRUNNER 3225 Black and White...
Where is the waste toner bottle on the xerox workcentre 5030 located at?
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
When I go to print it starts beeping and telling me to check waste toner box?
The waste toner box is located on the right hand side of the printer. There is a door/cover that opens up on the right side. It is a milky white plastic container. Check to make sure it is there and installed properly and the door is fully closed. If all that is correct it my be full.
There should be a new waste toner container in the toner box (along with a toner). The toner and waste toner are normally replaced at the same time.
If you don't have a new waste toner container you can tray emptying the one that is in the printer BUT be very careful. The toner is a fine powder and can get all over if spilled. If you ever spill toner never use water or any other liquid to try and clean it, that will just turn it to a liquid ink.Brush it off your cloths and vacuum it up.
If you do try and empty the container and the machine continues to tell you it needs to be replaced it can be because there is still toner on the inside of the toner container and the sensor is seeing it there.
I hope this is helpful,
Shawn
Jan 29, 2011 | Kyocera Mita FS-3820N Laser Printer
Waste toner tank
Here are the steps to replace the waste toner tank:
1. Turn the machine off, and then wait a few minutes for the machine to cool.
2. Open the front cover.
3. Pull the waste toner container out of the machine using its handle.
Note: Make sure that you lay the waste toner container on a flat surface so that the toner does not spill.
4. Remove the container's cap from the container as shown below, and use it to close the waste toner container opening.
Caution: Do not tilt or turn over the container.
5. Take a new waste toner container out of its package.
6. Insert the new container into position and then push it to make sure that it is firmly seated in place.
7. Close the front cover firmly.
Caution: If the front cover is not completely closed, the machine will not operate.
8. Turn the machine on.
Note: After rebooting, your machine will automatically reset the counter for the waste toner container.
Dec 02, 2010 | Samsung CLX 3160fn All-In-One Printer
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Refusing to take paper
Someone suggested to empty the gray toner waste container located on the left side of the printer next to the cartridges. Be careful when emptying this as toner can make a real mess. Clean up with toilet paper or paper towel - not water!
Easy fix and this fixed mine like a charm. No need to send the unit in!
Feb 17, 2009 | Samsung CLP 300 Laser Printer
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
Jun 17, 2008 | Samsung CLP 300 Laser Printer
Cannon Image Runner 5570
If the copier is indicating to empty waste toner bottle do as previously described. Until you reset the copy counter for the waste toner you will still get the message. Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's.
Nov 16, 2007 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5000 Copier Logo
69 people viewed this question
old marine
old marine
