Question about Acer AL1706AB LCD Monitor
Acer Monitor 1706
Power button flashes, but monitor will not display
  • glinda1960 Aug 10, 2008
    power light flaches on and off then if you wait one hour then the monitor will come on
  • knnthfix May 21, 2009
    I got this acer al 1706 real cheap, when i plug into a/c power, the power led flashes on and off about every two seconds. Unit will not turn on either. Will try to replace caps on the power distribution main board first.
I replaced the 470uf 25v capicitors and this fixed the problem. I had 2 monitors exactly same with the same problem and it fixed both of them.
Posted on Jul 21, 2009
There's a capacitor that's been overheating in the power distrubuting board. The light flashing means it tries to power on but the current is too unstable / wrong because of this one capacitor. I had the same problem myself with this exact screen.. It's a 470μ 25v capacitor.
Posted on Aug 07, 2008
  • 180 Answers
Defect in your main board.
Posted on Apr 22, 2008
How do you reset the monitor?
press menu button and choose display source. like VGA/ DVI or Display port.
Mar 28, 2015 | Hannspree Computers & Internet
Monitor will not come on flashing power button
Hello and welcome to FixYa!
As a first course of action, please secure the cable of the monitor going to the pc. If it's loosen, there will be no display and the power button will just flash or it will display NO SIGNAL. Please secure the cable and observe how it goes.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 11, 2011 | HP Compaq V720 17" CRT Monitor
I have a Wrist Blood Pressure monitor MF 81 that I would like to set the Date and time on it - I don't have a manual
Start with the unit turned off. Now hold the Power button on until it starts to blink zero (0) on the display. Wait until the display shows two zeros. Press and hold the Memory button until a two-digit number starts flashing at the bottom; this is the year setting. Press the Power button repeatedly until the year is correct. Now press the Memory button, and the month will start flashing at the top of the display. Press the Power button repeatedly until the month is correct, then press the Memory button. The day is now flashing. Set it with the Power button, then push Memory. The hour is now flashing, set it with the Power button (note that it is in 24-hour format, so 1 p.m. displays as 13). Press the Memory button to advance to the minutes, then use the Power button to set it. Finally, press the Memory button to turn the unit off. It is now ready for use.
Sep 04, 2010 | Mark Of Fitness MF 81 Wrist Blood Pressure...
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Samsung lcd monitor power button flashes and wont turn on or off
I have the same exact problem. The monitor seemed fine yesterday. Today, the power button light just flashes on and off, with nothing on the display.
Dec 05, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
LCD monitor no display - flashing power button
hello, my best guess is that the refresh rate is set for a crt monitor. hook your old one back up, if you can. and change it to 60 hertz or 70hertz. go 2 display properties then settings then advanced; then monitor. set the refresh rate as i said and turn off the computer, hook the new one back, and you should be good to go. good luck! and please rate this solution. if you need further assistance, reply
Apr 21, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Flash
When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
■ When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
● Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING
mode with the exception of MOVIE CLIP mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Acer AL1706AB LCD Monitor Logo
926 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
