Question about Sony KP-51WS500 51" Rear Projection Television
How do I fix the convergance on a sony 57" rear projection tv. Just started to look 3D the other day when turned on.flash focus does not help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 72 Answers
Get an ESR capicitor meter and check for dry or blown caps on the convergence board - replace the 2 convergence ICs (but ONLY do this if you are electronics qualified - or get a tech to do it). Clean the lenses of the tubes - these come completely apart and you can change the fluid too - usually this is a $250 per tube job (there are 3 tubes) for a tech but you can do this and replace the fluid yourself which will clean up the fuzzyness. Then reconverge and do the flash focus for all zooms (you may have to do this several times).
Here is a link too for the service manual which details how to converge your set - http://tv.groups.yahoo.com/group/Ws500/
Posted on Jul 16, 2010
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 11, 2010 | Sony KP-57WS500 57" Rear Projection...
Lookslike the picture is in 3d and when i try ti use magic focus
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 02, 2010 | Hitachi 57F500 57" Rear Projection...
The screen looks as if it is 3D. The colors are all offset.
  • Screen looks 3D
May 31, 2010 | Sony KP-57WS500 57" Rear Projection...
I have a 57 inch rear projection t.v. the color looks 3d and the screen looks warped. the t.v is about 10 years old but i would like to fix it myself if i can. please help.
  • Screen looks 3D
May 15, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Unable to perform convergence.
Ur 2 STK convergence ICS,and some or all it resistors are dead.U must know how to solders?Replaced the 2 STK convergence ICS and some or all it resistors,will auto focus ur convergence back to normal buy itself.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 10, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
I have a 57" sony kp-57ws500 rear projection t.v.
the tv he mentioned is not plasma or LCD, it's rear projection with tubes.
brad, you'll have to take off the front panel. there are two phillips head screws behind two small round plastic covers, one at each end of the bottom of the speaker covers. remove those, lift the cover slightly, then pull down. be careful because the plugs for the front panel controls don't have much slack. unplug those and set the cover aside.
there is a rectangular cover to the tubes and focus panel. remove that, set it aside and you'll have access to the focus and alignment controls. the white markings on the knobs are factory reference marks. IIRC, the top is the focus and the bottom is the alignment. use a flashlight to check because it's marked.
make the adjustment as necessary to get a clear picture. =)
Jan 07, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony rear projection tv will no longer focus. tried flash focus & manual focus
Convergence issue. The sony type 1 convergence kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and CD with instructions.
Dec 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Picture is distorted, double vision, looks like 3d.lines are arched or curve. colors don't line up. screen is bowed or warped. its a sony kp- 57ws600, 57 in. rear projection television. can you help me...
Try going into the video section of your menu, and pressing RESET on your remote control. If this doesn't fix it, try your quick start guide for setting the convergence and focus.
May 17, 2009 | Sony KP-57WV600 57" Rear Projection...
Double vision in red and green
Its failure of convergence ICs and will be replaced.
Convergence ICs are mounted on silver heat-sink on D board of TV
Let me know exact model number to help you with more technical info.
Mar 21, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
182 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
