Trouble light blinks 3 times - Heating & Cooling
  • Anonymous Apr 21, 2008
    My status LED flashing issue a fault code as follows 3 short flash and 1 long flash.
    Problem Solver:
  • 18 Answers
Need to stat brand name of equipment, differant manufacturers use different codes. There should be a listing on the front panel or on the inside of blower door with the wiring diagram. On some Carrier type it would be a code 31 , for inducer motor (vent motor) on a gas furnace or the pressure switch not making
Posted on May 16, 2008
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
What is the trouble when led light fault is lighted. and also zone 3 led lights is blinking?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 19, 2014 | Televison & Video
What is the trouble of our firedex 2204. led light fault is lighted. and also zone 3 led lights is blinking?
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Won't power on
You still have power supply trouble, even after replacement of the board. Recheck the replacement work; could be something wrong there
Jul 19, 2013 | Philips 47PFL7422D/37 Television
I have had the timing belt and kit replaced on my car along with a sensor and my check engine light will not go off so that i can pass the required emissions test for my state
you need to access the trouble code to better define the problem. insert key into ignition. you will need to turn the key to the position just before the engine cranks; the dash lights will be on. now turn the key back one click. You need to do this a total of 3 times ending in the on position( dash lights on-not cranking). Your trouble code will either show on the odometer( if it's digital) or will blink on the check engine light. count the number of blinks-pause-blinks etc. jot the numbers down. You can google the numbers to see what system is at fault.
Sep 17, 2010 | 1996 Plymouth Breeze
When i turn my key position to on the check engine light blinks 3 times stops and repeats
thats your on board computer telling you that all is fine with your car. if there is trouble,it will blink as you stated,then be followed by a series of erratic blinks,these are called trouble codes,and tell you what part is going bad.
May 02, 2010 | 1991 Dodge Shadow
Red Light Engine
you have a trouble code turn key off and on 3 times to make dash lites go on then off and on the 3rd time leave the key on and watch the lite it should start to blink count the blinks and let me know be careful cause there will be paulses betwin some to make up your trouble code ie 2 3 eqals code 23
Sep 19, 2008 | 1995 Jeep Cherokee
DEAD SET
http://www.chrisandnat.com/projects/BlinkingTV/Blink.htm
Aug 27, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Heating & Cooling Logo
486 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
