Question about HP LaserJet 5200 Printer
When print a file, the printer screen show ''Data Received'', So I can not print anything
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
The printer is missing something. Check if there is paper. also check to make sure you printed the right size paper. If you printed 8.5 x 11 sheet make sure that paper is in your tray or if you printed a different size make sure that paper is there. Than if all is good just restart your compouter and printer and it should be fine.
Posted on Jul 16, 2010
I am unavailable to connect via network
Most likely paper size is wrong. Push the cont. button on printer.
Adjust paper size on trays correctly. Make sure document size is same as paper size esp for PDF and postscript documents
Jul 08, 2014 | Edimax Computers & Internet
Hp 3005 printer, keeps printing text in a funny font,when not ordered to print,even when job is canceled, it shows data received then starts again printing the funny text
Might be askew codes. Check through which port it's printing?..Try with different port.Cancel all Que jobs.check with another data cablereplace formatter
Apr 08, 2011 | HP LaserJet P3005n Printer
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Printer won't print any Adobe files
When you click on "Print" do you get a window where you can choose the printer? If so, make sure you have you actual printer selected.
May 31, 2009 | Dell 946 All-In-One InkJet Printer
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
20 mem overflow
The printer received more data form the computer than can fit in its available user memory. You may have tried to transfer too many macros or soft fonts, or graphics that were too complex. This problem is also caused by printing too many typefaces at 600dpi. Press Continue to print the transferred data, then simplify your print job or install additional memory. I don't know why it would just start doing it, perhaps a memory module has gone bad and there is not as much available RAM as there used to be?
May 14, 2008 | HP LaserJet 4 plus Printer
Printer
try printing a test page. Make sure you have the right driver for your printer. Make sure all connection are secure and tight.
Mar 27, 2008 | Compaq Inkjet IJ650 Printer
89 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
