Question about Proscan PS32500 32" TV
ProScan PS32500 Will not stay turned on
I try to turn the TV on and it makes several attempts to turn on , making clicking noises, will not turn on.
The TV is 10 years old and I am wondering if it is worth repairing or not.
  • aquasco Jun 07, 2008
    the power buttom is loose the tv click on then go off
  • 71 Answers
Possibly flyback, probablly not worth fixing
Posted on Apr 27, 2008
Ok, so I got a RCA remote from 1800-remotes for $40.00 that they said is guaranteed to work with the Proscan but do I need to reprogram the remote because it is not working.
Hello
Just try with these four digit codes. Proceedings are given below.
0031 0107 0015 0000 0162 0163
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NOTE: Switch OFF and switch ON the tv with its front panel power control switch [NOT BY REMOTE CONTROL HANSET] before each try.
Dec 24, 2010 | Proscan PS32500 32" TV
My proscan tv will not stay on. Bought the TV about 1 1/2 years ago, sound is great and the color is prefect, it just turns off after about 5 minutes? Any suggests as to what the problem could be??
Take the tv aparts,check the Power switch see any burn marks,possible not holding connection.U know how to do soldering?Have sodering equipment,resolder the FBT,the Flyback Transformer,the big black block of plastic with the red wire with a cap hookup to the CRT(Tv Tub)
Jul 01, 2010 | Proscan PS32500 32" TV
32" proscan dual hd tv can't get universal or direct tv remote to work what now
Get a universal from big box and program. If you can find a rca remote, it should be programmed already.
Craig www.classtorations.com
Jun 08, 2008 | Proscan PS32500 32" TV
Proscan TV
Maybe, but I would first go into menu and look at audio settings and make sure speakers are on internal and not external or turn off.
Also just unplug for an hour and restart unit. Lastly, it may be cheaper to just attach a 100.00 surround sound system for audio.
May 27, 2008 | Proscan PS32500 32" TV
PS32500 32" TV Problem
The sound that you hear is coming from the sound detector not working or not receiving any audio. If the set is set to a second audio (SAP) program this could be you trouble. Some programs are broadcast this way. (such as Spanish for Spanish speaking people. Check you audio program settings.
Stargazer
Feb 19, 2008 | Proscan PS32500 32" TV
Power
they have a 5amp fuse ,if the fuse was gone there would be no turn on at all.the set is cycling trying to fire but there is a fault stopping it ,it called three strikes your out, the set is made to do this, you require service.possible horizontal or power supply,problem. ask for a est,
Dec 31, 2007 | Proscan PS32500 32" TV
Need Remote
You can buy a RCA universal remote that should work fine as RCA made the ProScan TV's.
Nov 30, 2007 | Proscan PS32500 32" TV
ProScan PS32500 32"-Picture has white static line & Static/burning smell
It sounds like the circuit board is arching over somewhere. It could be as simply as cleaning and digging out the carbon mark to stop the arching. This is most likely the screen or focus voltage causing this, if there are no parts that have broken down. This will damage the printed circuit board and make things worse the more you let this cook. This could be dangerous for you to mess with because of the high voltage present, so my best advise would be to get this into the repair shop as soon as possible before this board burns up. It should not cost all that much if the CRT board can be repaired. Good Luck
Mar 21, 2007 | Proscan PS32500 32" TV
Unable to turn on
Short circuit in High Voltage deflection circuit, usually the Horizontal output Transistor. What the 4 clicks are the power supply trying to turn on but it is sensing a short circuit..
Mar 20, 2007 | Proscan PS27125 27" TV
No audio
Make sure that the sources have audio to begin with. Carefuly check all menus and setups.
Yes. It is possible that the audio circuits in the TV have a fault.
Jerry G.
Sep 18, 2006 | Proscan PS32500 32" TV
Proscan PS32500 32" TV Logo
192 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
